Technical Is my Mallory Unilite broken?
Discussion in 'The Hokey Ass Message Board' started by BJR, May 12, 2023.
  1. BJR
    BJR
    I am trying to hook up the tach cable to my Mallory Unilite distributor. I can't get it to engage with the cable. It looks like the drive in the distributor is cracked and spread out. If you have one to compare, look at my picture and see if it looks broken to you. Or am I missing something that goes into the hole? This is on a 312 Y block in my 56 T-Bird. Mallory Unilite.jpg
  2. saltflats
    saltflats
    from Missouri
    Looks like it's made for a cable with a tang not the square cable end.
  3. SS327
    SS327
    Unscrew the adapter and take the gear out and see what it looks like. But it looks broken to me.
    BJR likes this.
  4. 19Eddy30
    19Eddy30
    from VA
    You should just be able to take out the driven gear & check fitment to your cable, (7/8 - 15/16?
    If split there are methods to fix the split, & if a tag drive it canbe accomplished with thought
    BJR likes this.
  5. Budget36
    Budget36
    I’ve never taken the cap off of my Chevy tach drive, but that looks round, more like a sleeve for the non-business part of the cable to ride on.
    As said before, take it off and look it over.
    BJR likes this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
  7. BJR
    BJR
    Where do I find the tang drive adapter?
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    2Blue2 and BJR like this.
  9. BJR
    BJR
    $33, wow that's almost as much as I paid for the cable.
    Moriarity likes this.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    I have bought plastic ones in the past, but I can't find them anymore...
    BJR likes this.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    I wonder if @e1956v could help with this? maybe he has a source for the adapters
    BJR likes this.
  12. saltflats
    saltflats
    from Missouri
    Can you not buy the proper cable?
    Desoto291Hemi and BJR like this.
  13. NoRust
    NoRust
    BJR and Moriarity like this.
  14. BJR
    BJR
    I already spent $40 on what was supposed to be the correct cable for a Unilite in a 56 T-Bird. So I don't know if I can.
  15. Mopars use a tang cable ,,,,and I guess Ford does as well .
    They work great !
    Tommy
    BJR likes this.
  16. lippy
    lippy
    from Ks
    I guess it depends on how bad you want to use it. Lippy
    BJR likes this.
  17. BJR
    BJR
    So true.
  18. ClayMart
    ClayMart
    BJR likes this.
  19. 19Eddy30
    19Eddy30
    from VA
    Can not tell by pic, if the square cable will fit is side of driven end
    (removed from driven housing),
    you could grease cable end , mix up some JB rap tape around gear stem fill up with JB, stick yr greased end in after it starts to harden , pull cable out , let it set/ harden fully, sand down excess !!
    A thought???
    BJR likes this.
