Folks Of Interest Is there a business like ENCO operating now?
Discussion in 'The Hokey Ass Message Board' started by Budget36, May 7, 2024.
  1. Budget36 likes this.
  2. sdluck
    sdluck
    LittleMachineShop.com
  3. Budget36
    Budget36
    If I make them in a pair, one can be flipped and will work. I recall when I ***emble it last time having to orient the slot correctly.
  4. Budget36
    Budget36
    I just realized what you were showing.
    Two at once at the needed angle then in the vice.
    Thanks
  5. Well, I had a great idea until I realized that I couldn't find a carbide hole saw that could cut to the needed depth. So Paulz idea will work, although I'd make one addition. Your cut shouldn't be the full 1/2 of the bit diameter, so put a steel spacer between the pieces. You'll have to figure out what's needed. I'd also put a heavy tack weld on each end so the pieces don't move in relation to each other. You can grind those off once drilled.
    TrailerTrashToo and Budget36 like this.
  6. bobss396
    bobss396
    This is exactly what you need to do, see the big circle? This looks like your part almost exactly. Plunge an endmill (can be a ball endmill) into the center of the big circle. From there you can hole-saw it, but go real slow and easy. Then mill off what material you don't need.
    If the radius is relatively shallow, you may be able to band saw them apart and clean up the cut edges. I would leave the material long so you can get your left-right parts out of one blank.
    Budget36 and continentaljohn like this.
  7. Budget36
    Budget36
    Ahh, yes. Bit more measurements show that it’s 3/4 inch at top. (Of where it was machined out.
    So I’m coming up with a plan, based on all the replies.
    thanks all!
  8. Budget36
    Budget36
    Sorry John, I meant to reply to this. But I don’t have the means to saw a 1 inch piece in half, length wise.
    I can chop it off, etc. but no band saw anymore.
    Well, I have something similar. But wouldn’t work.
  9. Budget36
    Budget36
    I do have several hole saws, so I’ll maybe look at a test run with one.
  10. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    I saw on ebay today new ball nose end mills for a little over 20 bucks. Good enough for a few projects? I would think so.
