Is there a company that drops headlight bars?
Discussion in 'The Hokey Ass Message Board' started by couverkid, Sep 29, 2008.
  1. couverkid
    couverkid
    Is there a person or company out there that drops original ford headlight bars? Just thought I would ask. I have a original 1932 ford headlight bar I want dropped.I heard there was someone in Phoenix, Arizona ?
  2. Deuce Roadster
    Deuce Roadster
    Gene McKinney in Riceville Tn used to. He may still drop them.
    r.exit42@gmail.com is his email address :)
  3. alchemy
    alchemy
    Can't you do that yourself? Got a buddy with an unpainted 32? Got a torch?
    Truth be told, it will probably need a little tweeking to fit your car exactly anyway, so why not do the whole job yourself? Heat at two hinge points on one end, then push down. Heat at two hinge points on other end, then push down. Step back and see what needs adjustment, reheat, then tweek.
  4. Mike
    Mike
    Call Frank at Premier Frame and Body, he has a fixture for dropping '32 light bars.
    602-267-1319
    3029 W. Clarendon
    Phoenix Az 85017
  5. Von Franco
    Von Franco
    Limeworks makes the best on man .............................
  6. Von Franco
    Von Franco
    Oopps i ment one.............
  7. jusjunk
    jusjunk
    from Michigan
    I do em . I dont have my jig set up for a 32 bar but it wouldnt take long with your bar as a pattern set it up. Right now im setup for 28-29 and 30-31.
    Dave
  8. Dale Fairfax
    Dale Fairfax
    Any particular reason why it has to be "an original" dropped? It's a lot of work to destroy a gennie part. You can buy a stainless dropped bar from Speedway for $120-I doubt if anybody would drop one for less than that. I made a jig (off a stock bar) several years ago and even split the bar into three pieces so I could chrome the center. Made three and looked at the finishing that remained and threw them in the corner. My car now has a stainless one from Speedway.
  9. jusjunk
    jusjunk
    from Michigan
    Well lets look at it this way.. If the guy wants to drop his original bar then whos to stop him... And I started doing it years ago just for fun. Im not gonna tell you how much i get but i will say your high but then again like i said i do it for fun and i havent filled my tanks for my torches in a while so i could be loosing money :D... Ya know Henry didnt make any gennie steel chopped 32 fords either ...
    Dave
