Hot Rods Is there a longer fuel pump rod?
Discussion in 'The Hokey Ass Message Board' started by meengrinch, Jun 26, 2017.
  1. meengrinch
    meengrinch
    from ipswich ma
    Fuel pump not pumping.......BBC rod length 5 3/4 in. Is there a longer Rod? Pumps on bench manually......????
  2. Phil1934
    Phil1934
  3. Blues4U
    Blues4U
    from So Cal
    SBC pump on a BBC?
  4. uncleandy 65
    uncleandy 65
    Have you got the correct fuel pump??
  5. Mark Roby
    Mark Roby
    The push rod is the same for BBC and SBC I believe. It's wrong pump or possibly something is wrong with the fuel pump eccentric
    BigPerm365 likes this.
  6. rjones35
    rjones35
    maybe it's just not priming, not pulling fuel from the tank. Will it run if you put some fuel in the carb and get it going a little?
  7. Mark Roby
    Mark Roby
    Excellent point
  8. VTjunk
    VTjunk
    Clogged filter? Seen it
  9. s55mercury66
    s55mercury66
    from SW Wyoming
    Years ago a friend put a 283 in his f100 with a front mount. He used a bolt that was too long and bound up his pushrod. Is that possible on a BBC?
    Hnstray likes this.
  10. Mark Roby
    Mark Roby
    Actually, I believe it is.
  11. s55mercury66
    s55mercury66
    from SW Wyoming
    If I remember in the morning, I will check the 402 in the garage.
  12. southcross2631
    southcross2631
    Could be something as simple as a pin hole in the fuel line and you are pumping air. It doesn't take a large hole and no fuel gets pumped. You don't have the fuel lines reversed on the pump ? Seen that done too. Try running a rubber line from a gas can to the inlet on the pump and check it out.
  13. s55mercury66
    s55mercury66
    from SW Wyoming
    Just an FYI, the 402 I have is not drilled through like a SBC is. Mine is a 72 version from a pickup. I could check the pushrod length if you wish, meengrinch. I probably shoulda done that in the first place.
