Is there a measurement for locating the 32 front crossmember?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Apr 4, 2008.
  1. Roothawg
    Roothawg
    I took a couple of days off to work on "Franken-jig", The worlds largest toe stumper.
    I have pretty much every thing located on the new 32 chassis I am building, except I can't find 2 dimensions, 1 on how far back the front crossmember sits and the other is the location for adding a rear crossmember for coil overs.
    I have the drawings from Wescott's site, any other good references. I have been running back and forth from my gennie 32 taking down dimensions but I have no idea how close the repro rails are to stock.
    Thanks
    Root
  2. Roothawg
    Roothawg
  3. You have the Wescotts blueprints?
  4. Roothawg
    Roothawg
    Yes. They have one measurement but it is pretty vague. I am relying on my gennie frame as long as the rest of the aftermarket pieces are accurate.
  5. Kerry
    Kerry
    Can't help you with the dimensions but heres a BTTT for you.
    How're the Fleetline, Fly and digger coming along?
  6. Roothawg
    Roothawg
    I am the king of new projects. The Fly is ready to roll, the Fleetline is on hold and Justin's model A is on the forefront.
    BTW, I have the situation remedied now. We'll see how it all looks soon.
  7. 54BOMB
    54BOMB
    What frame is under the 'fly?
  8. Kerry
    Kerry
    I had forgotten about Justin's A. Is he making any ground on it? Did you ever find the wheels you were looking for?
  9. Roothawg
    Roothawg
    Homemade.......
  10. Roothawg
    Roothawg
    I took off a couple of days to work on the "Franken-jig". The frame is coming together but it is a slow process since this is the first one.
  11. Stovebolt
    Stovebolt
    Can you enlighten the unwashed, or is it a secret???;)
  12. Roothawg
    Roothawg
    I just ended up making it match the gennie 32 frame I have. The cross members are a little different but I don't think it will make that much difference.
  13. fergenboysinc
    fergenboysinc
    I can measure my so-cal frame when I get home if that helps?
  14. Roothawg
    Roothawg
    Thanks but it is too late now....I welded that bad boy up.
  15. Stovebolt
    Stovebolt
    would you mind - for the rest of us that is?
  16. fergenboysinc
    fergenboysinc
    Sure! You tell me how you want me to messure and you got it!
  17. Stovebolt
    Stovebolt
    The distance from the leading edge of the front horn to the centre of a Model A front crocc member, and the centre of the rear axle to the rear edge of the frame horn - thanks.
    Cheers, and thanks from all the uninitiated for taking the effort.
  18. its 15 and 1\4" from the horn end on the top side of the rails to the centerline of the front crossmeber spring hole that will give you 106" wheelbase
  19. Stovebolt
    Stovebolt
    Thanks PV, we have now the knowledge to go forth and build...... spoken in a rather dramatic voice ;)
  20. Paul
    Paul
    Editor
    am I missing something here?
    the front crossmember info is plain as day on the drawing available at Wescott's
    and the rear coil-overs are going to be after-market,
    up to you the fabricator and the parts you choose.
  21. i don't know if your car will have fenders or not , buy if it will not you may want to consider moving the front crossmember 1" forward....So-Cal does that on their highboy frames.
  22. Roothawg
    Roothawg
    That's what I was kinda thinking of doing. Mike Bishop's book mentions that but I was unsure how that would look. I went with what was on the Wescott's drawing, hoping that my aftermarket crossmember would be close.
    Paul, I realize that I will have to fabricate the bracketry ,but I was kind of hoping that there was a standard of sorts for the rear coil over crossmember. I'll figure it out on my own. I always do.
  23. I Agree With Fenders It Looks Better With A 107 "wheelbase And Its Usually 7and 3/8 From The Rear Axle Centerline Back To The Coilover Crossmember Centerline If You Use A 1and 3/4 Crossmember.
