Technical Is There a Perch Pin Option for Me?/Wishbone ID?
Discussion in 'Traditional Hot Rods' started by Jax2A, Sep 15, 2022.
  1. Jax2A
    Jax2A
    So I was planning on using this old pair of 37ish? split wishbones I got on my T-touring/Model A frame project and just discovered an issue. However I just realized the Model A spring perch pins are too short! I measure outside spread of my split wishbones and found it is 4” which is an inch wider than the Model A wishbone 3” spread.
    First, is there a longer spring perch pin out there that will work with these spilt bones? If so, what should I be looking for?
    Second, can anyone ID the year(s) of these split bones? I know the spring perches have been cut off of them, that’s where I was planning to put my shock mount.
    Thanks for any help.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Looks like 40-41 bones. Ebay has some perch bolts listed for 40-41.
  3. adam401
    adam401
    Those are like 35 and later spring in front wishbones with the spring hanger part cutoff. Not sure what year. You can buy long aftermarket perches from speedway and a bunch of other places. They are for accepting a lower bolt on aftermarket shock mount.
    Jax2A likes this.
  4. 31Apickup
    31Apickup
    Just cut the top thinner on the bones and Remachine the taper, that’s what I did and seen others do. If you don’t need the mechanical brake portion of the perches you can get the aftermarket longer perches.
    Jax2A likes this.
  5. Jax2A
    Jax2A
    Thanks, I didn’t know longer ones were available.
    Thanks, I was wondering if that was possible but I thought it was cupped and not a straight taper. Do you know what degree reamer would be needed? I’d rather use my original Model A parts if possible even though I’ll be removing the mechanical brake attachment.
  6. seb fontana
    seb fontana
    from ct
    Countersink, 60°
    Jax2A likes this.
  7. Jax2A
    Jax2A
    Thanks for the help. Decided to order the longer perch pins. If I grind the bones thinner I won’t be able to mount my shocks on the bone yoke.
