Is there a quality BRUSH on primer out there?
Discussion in 'The Hokey Ass Message Board' started by powmia, Feb 10, 2013.
  1. powmia
    powmia
    So I have to leave home for work and I'll be gone for a few months and have to leave my bare metal roadster in a shop until I get back. I just invested a ton of time into getting it straight and really want to stop any rust that might come. Unfortunately I don't have any sort of air setup right now to spray anything. What would you guys suggest I seal it with that will protect it and make it easy to work with when I get back? I was going to do Eastwood epoxy primer and just roll it on with a small foam roller. What are your thoughts? It's in New Mexico so the air is dry but the storage is a barn type building with open ends.
  2. epoxy would be good, but foam roller will dissolve.
  3. ml_engr
    ml_engr
    HF has a cheap turbine HVLP setup. I have used it for shooting primer and it works well. Think it cost me $80 or so.
  4. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
  5. metal man
    metal man
    Are you going to remove it later,or is it going to stay? If it is going to stay, don't use anything other than a good epoxy primer. No reason you can't brush it.
  6. Unkl Ian
    Unkl Ian
    There is a quality roll on primer, to get away from VOCs.
  7. GREASER815
    GREASER815
    You have any rental places? You could buy a cheap $30 gun and rent a compressor for the day and prob not have $100 in it.
  8. powmia
    powmia
    I'll more than likely strip it when I get back anyway. Dont really want to, but I leave in a few days and dont really have the extra time to go buying the tools or renting stuff. If I can protect it for a few months it's worth the work later on to take it off right? I'd rather spray, but as far as I know there are no quality epoxies available in rattle cans.
  9. metal man
    metal man
    Well, if you are going to strip it, you may as well use rattlecans. The rattlecan stuff will wash off with laquer thinner when you get back, but it will protect it for a few months.
  10. You can roll primer on, shops do it in order to comply with not spraying coatings on the shop floor. PPG has a killer direct to metal epoxy in their industrial coatings division that is it table and sands like butter. Any auto paint jobber that sells PPG should be able to get it and it' very reasonably priced
  11. ssaahemifan
    ssaahemifan
    you could wipe it down with metal prep or a oshpho type product.
    As long as you don't touch it bare handed or it gets rained on it will last a long time before it rusts.
    I know you said building is open but your humidity is low ? right?
    Otherwise try PPG SX1060
  12. yep,wipe it down with a metal prep.will seal it for a while from rust and convert any starting rust.home depot sells jasco product.I use it alot and it works great.
  13. Weasel
    Weasel
    Rust Destroyer from Home Depot. I swear by this stuff. Brush on is better than rattle can as it lays on thicker. I have stuff protected for years with this and I have painted over clean metal - none better IMO....
    RUST DESTROYER PRIMER GALLON, Whether it's a home barbecue or a major suspension bridge that needs sprucing up, you can turn to RUST DESTROYER®, a product so unique it is the only solvent-based non-toxic, patented, USDA-approved, FDA-approved universal base rust converting paint primer with a 5 year guarantee. With all the "rust converting" products and metal primers, why should you buy RUST DESTROYER® You should not be forced to buy a separate primer or rust treatment for each specific job! RUST DESTROYER® the patented universal paint primer, and rust converter does it all! One SKU. Lets you avoid confusing your customers. RUST DESTROYER® is so unique it is patented. Is non-toxic, USDA and FDA approved. Is heat resistant up to 800of. Has a Five-Year Guarantee. You don't have to pour RUST DESTROYER® into a separate non metal container, as most others say. RUST DESTROYER® can be applied by brush, roller, conventional spray or airless spray. RUST DESTROYER® will work on: clean steel. rusty steel. zinc galvanized metal. hot dip zinc galvanized metal. core tan steel. aluminum. tin. previously painted surfaces. great for barbecues. No special surface treatment needed. No sanding or deglossing needed, on glossy surfaces. Remove the loose flakes, have a paintable surface, apply product. RUST DESTROYER® is a self etching primer that "bites" into the previously painted surface.
  14. tinwizard
    tinwizard
    from Northwest
    Hmmmm ..... so how much a gallon is the stuff? And can it go on over other primers and not turn it into a bubbled mess? What about after this has been on a while .... what will go on over it and not have problems also?? IF it can be on any surface and allow resurfacing with most anything later .. it almost seems too good, and that would be great!!
    Regards,
    Tinwizard
  15. ronzmtrwrx
    ronzmtrwrx
    Any automotive paint supply store will have rollers that won't come apart. I have used them on several occasions with DP epoxies on small areas.
  16. Rusty O'Toole
    Rusty O'Toole
    If the car is indoors wipe the bare metal with oil and it will keep for weeks or months. Grease even longer.
    You will have to wash it off with gas and Prepsol before you primer and paint.
  17. no55mad
    no55mad
    Zinc Chromate - used it with the cheap low nap 3" rollers. Transfer the paint to a squeeze bottle, squeeze out some paint and roll it out.
  18. 3340
    3340
    What Rusty O Toole Said.
  19. Napa has some spray on green etch primer. Sorta high.....Second thought PeP boys was cheaper. Don't remember the brand.
  20. Mr48chev
  21. with tax looks like just shy of $100 a gallon.
  22. Normbc9
    Normbc9
    There are still are a few quality old time auto finish brush painters out there. Look in the Restorers sites. Some still advertise. This is a sample of that work.
    Normbc9
  23. Just use rattle can zinc chromate, goes on thin almost transparent. You don't need to put a heavy coat on or spray bomb metal etch. Metal etch is pricey thou.
  24. jesse1980
    jesse1980
    Just use rattle can primer if your taking it off anyway.
