Is there a trick to removing a pumpkin from a 9" Ford?
Discussion in 'The Hokey Ass Message Board' started by Frank, May 17, 2006.
  1. Frank
    Frank
    I have a loose rearend (save the jokes.) Its a late 60's Ford 9" from a truck. I've already pulled out the axles and all removed all of the nuts from around the pumpkin but I can't get the darn thing separated from the housing. I figure its just a really really good seal. Thought I'd ask if there were any super cool HAMBer tips? I can't get a anything between the halves to pry it apart.
  2. sonic reducer
    sonic reducer
    tap tap taparooo with the maul.
    tapping a knife blade, razor blade etc into the seal can split a little, Ive used that to split trans from a block before. you will probably break razor blades so I would use a paring knife or old crappy pocketknife.
  3. hemispherical
    hemispherical
    from indiana
    we remove ours frequently from an alcohol funny car. the way i do it is start with a 1 to 2 inch wide paint sraper and tap it in between the housing and the center section. you may have tried this already but my .02 and works every time
  4. jetmek
    jetmek
    the copper seal washers on the studs might be holding things up on you if they are still on it...
  5. enginebloch
    enginebloch
    from norfolk va
    I do quite a few of them a month and I take a brass punch and knock the studs in. Its the best and easiest way i've found so far. Its not too hard to press them back in by tightening a nut on them before you replace the pumpkin.
  6. scottybaccus
    scottybaccus
    Personally, I just use a few choice four (or more) letter words and intimidate the shit out of it. I know the job is done when it pisses gear oil all over my floor....
  7. Godzilla
    Godzilla
    I have a tool that I made out of an old LARGE screw driver. Ground it down so that it is like a scraper on the end...but it is not so flexable...just drive it in carefully after a good dosing with panther piss down all the bolts. No problem.....Good Luck. Ron.
  8. squirrel
    I used to do that at the junkyard on the cars we were gonna crush, and wanted to save the pumpkins.
    I'd be a bit leery of doing it to a housing I want to use, because of the possibility of stripping the splines on a stud hole, but apparently you don't have any trouble....
