Technical is there a way to make clear canopys
Discussion in 'Traditional Hot Rods' started by james reynolds, Nov 21, 2017.
  1. james reynolds
    james reynolds
    recently i saw something in a h.a.m.b. post that made me think you guys might know how to make canopy bubbles alah jet fighter look just curious and thought it might be handy to know how
  2. sloppy jalopies
    sloppy jalopies
    memory says street rodder did a series on making ed roth style bubbles... H I H...
  3. james reynolds
    james reynolds
    sorry for my ignorance not much time in forums is there a way to search this forum by name
  4. Todd's Canopies Ft Lauderdale, Fl
  5. james reynolds
    james reynolds
    you know it amazes me how innovative folks can be when they get to crafting cars
  6. squirrel
    cut a hole in a piece of plywood, sandwich the flat plastic between that and another full sheet of plywood, which has an air hose fitting in it. Put it in an oven, get it warm, then turn on the air.
    We made a little one in college, but that was a long long time ago. I'd suggest going with the pros, if you plan on building a nice car.
  7. james reynolds
    james reynolds
    basically same as hydroforming with air sweet thanks
  8. james reynolds
    james reynolds
    i was thinking i could make custom dome lights or tail light lens this way
  9. squirrel
    Sure, you can try it at home.
  10. sloppy jalopies
    sloppy jalopies
    IMO...
    get a cheapo toaster oven, [wife doesn't want you to use hers].
    I used '70's F1 tail light lenses... place 2 metal blocks in the oven...
    tested pre heating on s**** plastic strips.
    use a baker's timer, test how long and what temp will let the s****s sag...
    then set up your "dies", slide the whole thing into the preheated oven, set the timer...
    watch closely so it doesn't melt... spay bottle with water could save it if too hot...
    made a red third brake light lens for a '38-'39 plate light housing... even lined up the magnifier with the bulb's element... worked slick...
  11. belair
    belair
    Look for threads by plowboy. He built a couple.
  12. john walker
    john walker
    I met Ed Roth years ago in Seattle where he was sponsoring independent short films of all things and asked him how he made bubble tops. He did it as Squirrel describes and used a friend's large bakery oven.
  13. james reynolds
    james reynolds
    yeah thats the plan i knew someone would have done it before
    my wife worked in a plant that did injection and extrusion moulded plastics(we both work in a plant that makes things from sheet round and square bar metal a.t.m.) and i used to ask about every process in there also my nephew was a mold changer at the same plant i have enough basic knowledge to pull off sag moulding plastics i think i could even do crude injection moulding its the moulds that become the issue there but the skill to make a wood mold for sag molding would be much less technical than one from tool steel not to mention the huge cost difference.
  14. rjones35
    rjones35
    Like this -
    Full Custom Garage. He has done a few different projects involving blown bubble tops, or lenses, or something else.
  15. james reynolds
    james reynolds
    hehe AWESOME!!
  16. HOTRODPRIMER
    HOTRODPRIMER
    Do a search for Plowboy or the Atomic Punk,he is a master of the bubble. HRP
    And if you build it right you too might end up at the ******* Manson.
    mgtstumpy and loudbang like this.
  17. Bandit Billy
    Bandit Billy
    Since Charley died today, and Hugh died a week or so ago, I think it ironic that you Freudian slipped and spelled ******* Manson. :cool:
  18. kabinenroller
    kabinenroller
    One of my cars has a bubble roof, I purchased the top from Germany. The optics are perfect, in fact the original top for this car had more distortion than the repro.
    I believe it was vacuum formed.
    Jim
    80971FD3-2AC2-4490-B442-6CBCBCF852ED.jpeg B5457DF2-73CA-40A6-A37D-9A0FFE2492CA.jpeg
    mgtstumpy, loudbang and kidcampbell71 like this.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    Aaron bought a ready made round bubbletop for his car
    I built the plywood blow form mold to do the one on Ed Roth’s road agent when I owned it and I built the mold for the one on the Futurian that I built[​IMG][​IMG][​IMG]
    Also before I built the one for the road agent I did a small test bubble in my kitchen oven
    [​IMG][​IMG]
  20. gnichols
    gnichols
    from Tampa, FL
    Check out the power boat builders. Or experimental aircraft builders. Gary
