Technical Is there any coating that is impervious to brake fluid?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jul 18, 2022.
  1. saltflats
    saltflats
    from Missouri
    That makes it easier, no flushing required.
  2. kabinenroller
    kabinenroller
    Roothawg likes this.
  3. alanp561
    alanp561
    It'll leak right through that ;)
    dmar836, Ned Ludd, Budget36 and 3 others like this.
  4. Roothawg
    Roothawg
    You Sir are a prophet.
    Rickybop and alanp561 like this.
  5. If you are used to a firm pedal; silicone fluid may take getting used to.
  6. Rickybop
    Rickybop
    Paper? No flushing?
    Did we change the subject?
    I should pay better attention.
    alanp561, Roothawg and 427 sleeper like this.
  7. gimpyshotrods
    gimpyshotrods
    I am pretty sure rust is impervious to brake fluid.
    It's also traditional.
    alanp561, indyjps, Budget36 and 3 others like this.
  8. All brake fluid is “synthetic”
    I find modern catalysed paints aren’t bothered much by brake fluid if it’s cleaned up right away.
  9. jimmy six
    jimmy six
    Not mentioned but Imron paint but it was the best paint I ever found in an industrial application. It was used on cars but it could kill you in the booth.
    Chavezk21, rbrewer, alanp561 and 3 others like this.
  10. Roothawg
    Roothawg
    Rust sucks. I'm not a patina guy...
  11. Hillbilly Werewolf
    Hillbilly Werewolf
    I dont know how a chrome plater would be able to keep the bore in tolerance, obviously they make it work.
    I would think that a freshly chromed master could be bored and sleeved by a place like White Post restoration.
    Atwater Mike and 427 sleeper like this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    Chrome is lazy and won’t go very far into a hole
  13. Not generally a problem because plating won't go into holes unless special fixturing is done.
  14. saltracer219
    saltracer219
    If your pedal feel is any different than conventional fluid than you have air in the system. Silicone fluid is difficult to bleed, it is very easy to end up with air in the system. You cannot pump the pedal during the bleeding process like you would do with conventional fluid. You have to be very gentle with the pedal or use a vacuum pump at the wheel cylinders or have a dedicated pressure bleeder to get good results.
  15. Roothawg
    Roothawg
    Honestly, I am a creature of habit. I doubt I will convert. It would be easier for me to just plate the MC.
    427 sleeper, SS327 and Moriarity like this.
  16. KenC
    KenC
    I happen to have a couple of qts of Imron black, so last week I shot the brake and clutch masters with it, hoping that it is a tough as its reputation. The seat frame, riser and probably the grille gars and bumpers will get the same treatment. 56 Dodge 1/2t
    Chavezk21 and Roothawg like this.
  17. 55blacktie
    55blacktie
    When I inherited my dad's 55 Tbird, I discovered he had put a note on the master cylinder that said, "Silicone Brake Fluid Only." The car had the original single-circuit master and drum brakes. The brakes functioned as well as any non power-assisted drum brakes, and I had no complaints about pedal feel.
    saltracer219 and Roothawg like this.
  18. Roothawg
    Roothawg
    I have never owned anything that had DOT5 that I know of. I'm sure it is good stuff, but I have a lot of crap running the old stuff.
    427 sleeper likes this.
  19. alanp561
    alanp561
    Worked for a fellow in Michigan who had a water blasting business doing work mostly for GM cleaning out their paint booths at the Lordstown, OH plant, the truck plant in Flint, MI and the Camaro/Firebird plant in Van Nuys, CA. Extremely high-pressure, high-volume pumping units throwing a 3/16" stream of water out of the nozzle at 8500-10,000 PSI. You could saw right through a telephone pole in under 8 seconds. I built the trailers for these units and painted them with Imron. The Imron withstood accidental direct hits from the water blaster, having hoses and equipment loaded time and time again and contact with other equipment as the units were moved from location to location. Really tough stuff. I reckon it will hold up to your brake fluid.
    427 sleeper and Roothawg like this.
  20. Roothawg
    Roothawg
    I’m afraid that the Imron everyone remembers is long gone. Last time I checked they had converted to a bc/cc.
  21. alanp561
    alanp561
    Well, that just sucks!:(
  22. wahoo
    wahoo
    I have used the Eastwood paint on 2 vehicles and am very happy with it.
    I didn't have my pressure bleeder on tight and made a mess on one of them. Cleaned it off w/ brakleen and the paint looks fine. Only comes in cast color though.
  23. To me; it has always appeared that brake fluid migrated under the edge of the paint at the cap or cover and spread destruction from there.
    alanp561 and Roothawg like this.
  24. A Boner
    A Boner
    Unless it’s a race car…the positives of silicone far outweigh the negatives. Zero issues with paint damage for the win.
    ottoman, Roothawg and saltracer219 like this.
  25. Maybe the fluid was different back in olden times. We did three cars with a jug of silicone fluid from the Deuce Factory when it was the new hot thing, all simple systems, four wheel drums and a fruit jar single master. All had that tiny bit of softness at first touch. While we didn't have those whiz bang vacuum suckers and wouldn't even think to invest in dedicated pressure ball; I could bleed brakes. Back then it was noted that the fluid was slightly compressible. Maybe the current stuff is different.
    Moriarity and Roothawg like this.
  26. KenC
    KenC
    Fortunately (for me) the Imron I'm using on the 54 that I mentioned earlier is old stuff. Old enough that the hardener is in a qt rectangular screw top metal container. Still good after all these years.
    alanp561, RICH B and Roothawg like this.
  27. cretin
    cretin
    We have recently been experimenting with air cured Cerakote.
    We sprayed some on a panel, and poured some brake fluid on it, and left it for hours.
    It did nothing to the Cerakote. Colors are a bit limited though.
    alanp561 and RICH B like this.
  28. Roothawg
    Roothawg
    I was wondering about that. I have been reading their website recently.
  29. 55blacktie
    55blacktie
    By the way, all of the brake lines were OEM, nothing fancy. However, I will be using braided SS and SS hard lines when finished with Wilwood front disc conversion.
  30. blowby
    blowby
    from Nicasio Ca
    Mine is just black rattle can engine enamel. I touched it about a year ago with a brush, blends in fine on the rough casting. It's not a leaker and not a show car.
