Projects Is this "2door"- able?
Discussion in 'The Hokey Ass Message Board' started by 58Fridge100, Apr 23, 2009.
  1. Doesn't look like a 2 door to me. Has 4 doors ... ?? The difference? One has 2 doors and one has 4 doors .. ?? Nice lookin' ride though ...
  2. RayMiller
    RayMiller
    the doors on the two door are longer than that of a four door, it appears to be a super clean car though
  3. Squablow
    Squablow
    You'll need the longer 2 door sedan doors and a big section of the quarters including door jamb and window frame from a 2 door post donor car to swap it over. The C pillar of the 4 door sedan is a lot different than the 2 door C-pillar so using the old 4 door rear door as a filler is not going to work if you want it to look like stock.
    But yes, it is very do-able. So-Cal Tex did a recent tech on a conversion that you could use as a guide, I would do it the way he did it for a seamless, factory correct look. I would consider a conversion on that car to be a worthwhile undertaking if you have the parts car to do it.
    If you see one in a direct side shot, it's obvious how much shorter the front door is compared to a 2 door sedan, so if you're thinking about welding the rear door shut, forget about it, it'll look like***** and be super obvious. But to do it right with the correct parts is very possible.
  4. Squablow
    Squablow
  5. chaddilac
    chaddilac
    Yes it is!!! get it!
  6. C-post is a lot different on the 4dr from the 2-door. $3500 is a lot for a 4-door '54 Chevy that's not perfect, to turn around and hack up.
  7. Slide
    Slide
