Is this a 1932 Ford transmission?...
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, May 25, 2011.
  1. 3wLarry
    3wLarry
    from Owasso, Ok
    Was told it is...then someone told me it isn't...???
    kidcampbell71 likes this.
  2. johnny bondo
    johnny bondo
    from illinois
  3. chaddilac
    chaddilac
    According to your for sale thread it is!! :D
  4. 3wLarry
    3wLarry
    from Owasso, Ok
    That's why I'm trying to find out if it is or not...I don't want to mislead anyone.
  5. chaddilac
    chaddilac
    I was just messin' Larry... I was going to paste your thread url in there and tell you to match it up to the photos!! :D
  6. Will Kimble
    Will Kimble
    Well it looks like a '32 handbrake & ratchet, and the shift tower looks right for '32. Case looks like for a Model B 4 cylinder. Rear mount is not '32, maybe '37-39? Looks like somebody already snarked the clutch arm...
  7. 3wLarry
    3wLarry
    from Owasso, Ok
    'splain "snarked the clutch arm"
  8. Will Kimble
    Will Kimble
    Looks like the clutch arm is gone. Should be a long, slender thing. It was one year only of course, and one of two pieces - including the original rear mount - that I would want off a '32 B transmission.
    Will
  9. HOTRODPRIMER
    HOTRODPRIMER
    The case looks right and the early shifter has the correct slight curve but the rear support isn't right for a 32.HRP
  10. titus
    titus
    someone probably stuck a B motor in a 37-41 ish ford, that would explain the different rear mount, they all interechange off the back of the trans anyways.
  11. phlip
    phlip
  12. hotcoupe
    hotcoupe
    the number that is stamped on the case near the inspection whole will indicate the year of manufacture.
  13. Chris
    Chris
    Yep, 1932 4 banger trans. Has a new rear mount, but with that tower yes it is a 32
  14. -Brent-
    -Brent-
    3W... doesn't know his thirty-two parts? Tisk tisk... :D
  15. 3wLarry
    3wLarry
    from Owasso, Ok
    I knew you would know...:) Thanks, man.
  16. 3wLarry
    3wLarry
    from Owasso, Ok
    Hush up, you...
  17. Bruce Lancaster
    Bruce Lancaster
    Serial would be on the NEXT layer, a piece betwixt trans and block on B.
    Top '32 for sure...case used '33-4 too, but with a couple added notches that I do not see on yours...so all is '32 except rear mount.
    Clutch arm is a big chunk of value, very expensive now.
    See this site: http://www.fordgarage.com/ and find your way to actual pics of the difference between B castings, '32 and '33-4!
  18. 3wLarry
    3wLarry
    from Owasso, Ok
    Thanks Bruce :)
  19. This would be true for a V8 but the 4 cylinder cars had the number stamped into a boss located on the flywheel housing (the piece between the transmission and the engine).
    Charlie Stephens
  20. truckncoupe
    truckncoupe
    I don't know Larry ? Looks like a LATE MODEL PINTO TRANSMISSION!:D
  21. rusty bill
    rusty bill
    Bruce is correct!
  22. Smokin Joe
    Smokin Joe
    Henry never missed a chance to use up inventory. They'd use up all the stuff from the previous year before starting on the new stuff and if next year's parts started comming in they'd use those too if they were closer than the correct parts to the production line and they'd do the job. Bottom line for them was if it's handy and it fits, use it, don't hold up the line. Not saying that's what happened here but something to keep in mind when looking at old Ford stuff.
    The other half of this is there have been lots of mechanics and hot rodders over all those years to swap parts together to meet what they need.
  23. deucegarage
    deucegarage
    1932 case (not 33-34)
    1932 Hand brake
    1932 Shift Tower (not later)
    post-1936 rear main bearing retainer.
