Is this A 32 V8 REAR?
Discussion in 'The Hokey Ass Message Board' started by rats28, Aug 27, 2010.
  1. rats28
    rats28
    from Louisiana
    Looks like the radius rod tabs are on an angle so it would be a 32 v8 rear right? the 32A style tabs were mounted straight
  2. Fogger
    Fogger
    The Model A '32 axle had a round flange where the torque tube bolted to the banjo. The V8 was scalloped like the '33 and '34.
  3. rats28
    rats28
    from Louisiana
    SO is this the v8 rear?
  4. Andy
    Andy
    It is a 33-34 rear.
    You need some radius rods for it?
  5. cuznbrucie
    cuznbrucie
    I believe it is later than a '33-34........didn't the spring have a compound curve like the '32? The spring in the picture is straight across, more like a '40...........anybody else see it that way?
    CB
  6. HotRodFreak
    HotRodFreak
    If the driveshaft outer tube measures 53 3/8 +/- it is 32 length,
    ***uming my memory is correct.
    I can measure one of mine if needed.
  7. hotcoupe
    hotcoupe
    it appears to be a late `32 (that would be a very good find) or a `33 -`34. the length of the torque tube will determine whether it is a `32 or `33-`34. i`m basing my statements on the fact that it has angled radius rod brackets on the axle tube and also scalloped flange on the banjo housing.
  8. AJofHollywood
    AJofHollywood
    I happened to see pair of actual 1932 rear radius rods on ebay that end Sunday, $20 no bids yet.
  9. hotrawd
    hotrawd
    from lima,ohio
    If I remember right (sometimes I don't), the radius rod mounts on a '32 were straight. The '33 &'34's were angled.
  10. hotcoupe
    hotcoupe
    the radius rod mounts on the "early" `32 axle were straight (parallel to the torque tube) the "late `32 axle had angled mounts.
  11. cuznbrucie
    cuznbrucie
    Look at the brake drums on that rear........they are solid like a 1940......I do not believe this rear is a '32, 33 or 34..........am I wrong? The brake drums would be vented on a '33-34.......
    And the banjo looks pretty wide in the center section to be that early.....
    And, are the backing plates fitted with hydraulic wheel cylinders?......or do they have mechanical connectors?
    I still think it is later........1940+
    CB
  12. rats28
    rats28
    from Louisiana
    Need help befor i buy the torque tube he says measure 61" he said the width from out side of brake drum to out side is 57 3/4 is this a 32 late model rear?
  13. rschilp
    rschilp
    Just measured a '33/'34 rear I've got on my LandSpeedRacer mockup and it's ~51 3/8" inside flange to flange (I've got the original brakes)
  14. duste01
    duste01
