Is this a 392?
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Apr 28, 2007.
  1. panhead_pete
    panhead_pete
    Have been told this is a 392, but am not sure on how to ID hemi's.
  2. panhead_pete
    panhead_pete
    Well I love the power of the internet. It appears it is 392. Is this correct? If so how can I tell if its a 325hp motor or a 375hp (from a letter car???)
    Do those 9's and 6's look right????
  3. Omega
    Omega
    from Mass
    Theres plenty of threads that tell ya how to ID a Hemi... SEARCH! (I dont mean that in a asshole way either =)
  4. Machinos
    Machinos
    I believe the NE57 means it's from a '57, which in itself would make it a 392, but you can also tell because it's got that seperate water crossover manifold. All hemis from 300's had dual quads so it's "just" a regular one.
  5. 2manybillz
    2manybillz
    The humps cast into the end of the heads look like it's a 392. High HP letter cars have dual quads and adjustable rockers.
  6. panhead_pete
    panhead_pete
    Thanks guys, going on the number and water cross over it is a 392 but does that serial number look suss? Those 6's and 9's seem a different style to the other numbers?
  7. ol fueler
    ol fueler
    The numbers are ok. A 300 block woud start 3NE-------
  8. man-a-fre
    man-a-fre
    Its a 392 sir.
  9. panhead_pete
    panhead_pete
    Thanks guys, just trying to get my head around the price of it - almost $6K(US) here in Australia.
  10. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Pete.....those last numbers on the block do not look like a factory stamp....
    make sure and be careful...6K is spendy.
    Just my take is all.
  11. panhead_pete
    panhead_pete
    Thanks - yeah Im nervous about that too. Anyone else have a view on it or preferably a picture of a factory 9 and 6. Thanks.
  12. Chris Casny
    Chris Casny
    Even the #4 looks kind weird
  13. DE SOTO
    DE SOTO
    RELAX..... THE NUMBERS ON THERE ARE FINE !!!
    THOSE ARE FACTORY MoPar STAMPED #s,
    IF NOT, THEN I GUESS I SHOULD FIND OUT WHO STAMPED ALL 3 OF MY DeSoto's AND BOTH MY 331 CHRYSLERS !!!
    CHRYSLER DID THAT SO THEY ONLY HAD 1 STAMP FOR THE 6 & 9, AND ITS DISTINCTIVE OF MoPar....... KINDA LIKE HARLEY DAVIDSON DID THE SAME THING, SO YOUR AVERAGE JOE DIDNT GO STAMPING #s IN STOLEN ENGINES.
    SMALL BLOCK CHEVY GUYS SHOULDNT COMMENT ON A HEMI QUESTION ....... THEY JUST DISTURBE THE PEACE !!
  14. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Really?.well I will go out to the shop today and check my hemis for there numbers....I will take pics and upload them later today.
  15. breeder
    breeder
    not to rob this thread but, wheres those numbers at in the pic????i have a 392 sittin in my yard an would like to figure out just what it is!
    again, sorry to rob your thread pete!:eek:
  16. Turbopackman
    Turbopackman
    Front edge of the valley pan.
  17. squirrel
    Some of us chevy folks know that mopar numbers look really funky like some guy stamped them at home with a cold chisel, and that the ones shown in the pic are legit.....
  18. 19Fordy
    19Fordy
    According to my hemi book it's a 1957 Chrysler FirePower Hemi, 392, 4 inch bore x 3.906 stroke, 325HP @ 4600RPM, 430 foot pounds of torque@2800 rpm, 9.25 compression ratio, 4 BBL carb, 6.95 rod length, 2 Inch intake exhaust valves, 1.75 dia exhaust valves, came out of a Chrysler new Yorker.
  19. DE SOTO
    DE SOTO
    I GUESS I SHOULD HAVE SAID "SMALL BLOCK GUYS .. EXCEPT SQUIRELL"" :D
  20. squirrel
    actually I'm a big block chevy guy, I got over the small block stuff a while ago.
    And I do have some hemi stuff laying around, a few 331 bits and a pile of rust desoto
  21. numbers look right and the 392 has a 1/4 taller deck height, the heads were cast with the 1/4 risers to compensate and allow the manifolds to interchange with earlier models.
    The 354's had the same cross over. so that's not a sole factor for ID
  22. The deck on the 392 is 1/2 inch taller than that of the 331 and 354. thats why the are called a tall deck. the heads are the same in physicle size and have the intake runners lower on the head (closer to the block) so the manifold sets lower to keep the carbs low and to keep the same plane as the 354 and the 331 engines. 392 heads are 392 heads only. the smaller ones will work with 1/4 spacers to make up for the increased deck height.
  23. jj mack
    jj mack
    To add to what Hot Rod Packard said....The water outlets are also lower. On 392 heads you can put your thumb on top of the water outlet and not touch or cover the valve cover gasket. You can not do this on 354 or 331 (with a water cross over). From the pics, you can easily do this, so these are 392 heads. The 392 blocks do have a deck height of 1/2 taller (not 1/4). I can not tell from your pics if this one is or not.
  24. ProEnfo
    ProEnfo
    from Motown
    Hemi engine stampings.... from a SBC guy..:D
    CC
