Is this a factory built wheel?
Discussion in 'Off Topic Hot Rods & Customs' started by Driver50x, Sep 25, 2025.
  1. Driver50x
    Driver50x
    This one is causing a big argument over on Facebook. Lol.
    It’s a 4 lug / 5 lug wheel. Does anyone recall these things being sold by any of the aftermarket companies? Or was this thing modified in someone’s garage?
  2. SS327
    SS327
    That’s a home build. Nobody would do that to one of their wheels from the factory.
    Deuces, 19Eddy30, squirrel and 3 others like this.
  3. I fail to see the source of your confusion :D
    Deuces, SS327, mrspeedyt and 3 others like this.
  4. slowmotion
    slowmotion
    Home butchery at it's finest....:eek:
    Deuces and Gasser 57 like this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    A for excellent machining.
    Okie Pete and squirrel like this.
  6. Driver50x
    Driver50x
    That was my guess. It was somebody who works in a machine shop, or at least has their own mill at home.
  7. swade41
    swade41
    from Buffalo,NY
    4 lug that someone drilled for 5 lug ???
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    4+5=9 5+4=9 Same difference right?
    Deuces, porkshop, SS327 and 2 others like this.
  9. Like mentioned by others on original FB post. I've seen plenty of cheap aftermarket wheels drilled like that from the factory
  10. Gasser 57
    Gasser 57
    from New Jersey
    What a butcher job.
    Deuces and SS327 like this.
  11. swade41
    swade41
    from Buffalo,NY
    I'd like to see the back of it, to see if one of the patterns is in the webbing or if it's a solid wheel on back.
    Driver50x, Johnny Gee and Deuces like this.
  12. 19Eddy30
    19Eddy30
    from VA
    If that wheel is OEM ,
    I could see some one grabbing out of parts bin to Modified to use maybe on test track / scenario. Just like shifter in Cobra's
  13. Harv
    Harv
    from Sydney
    A machine shop supervisor would (should…) not let that out the door.
    I’ve seen apprentices doing poor quality “foreign orders” (work for their home) only to have the apprentice master bin it and make them do it properly.
    cheers,
    Harv
    Driver50x likes this.
  14. Matt Dudley
    Matt Dudley
    from New York
    For sure it’s re drilled. I know with the EA series Subaru cars ( Loyale and prior )which had an odd bolt pattern, people would re drill I think 6 lug wheels as someone had a template to do it. The bolt holes on those were not close. always thought it was janky and I’d never do it myself
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I guess this should be outlawed as well. :rolleyes: IMG_4706.jpeg
    Deuces and 19Eddy30 like this.
  16. 19Eddy30
    19Eddy30
    from VA
    Maybe a Cuban modification ?
    Seen some unique thinking before Cuba was Reopened, A cap/ disc wound Cover up .
    Back in late 80's when Ford Rangers came
    With Aluminum Looking Centerline Oem wheel's
    Filing bolt holes to fit Gm , did not have Mill then .
    Back before outlawing split wheels using block of wood to Center wheel to hub as tightening hub lugs .
    SS327 likes this.
  17. MAD MIKE
    MAD MIKE
    from 94577
    If the 4 lug pattern is 4x108mm, I'mma guess someone with a Pinto/MII liked the factory slotted wheel look, but wanted something other than 13".
  18. deathrowdave
    deathrowdave
    from NKy
    Man I need 4 x108 ( 4 x4.25 ) x 14 slots . 4 of them
  19. Driver50x
    Driver50x
    I love slots too.
  20. proartguy
    proartguy
    from Sparks, NV
    That wheel scares me just looking at it.
  21. Very scary!!:confused::eek:o_O
  22. Bandit Billy
    Bandit Billy
    I wouldn't coil my garden hose around that thing.
    Lone Star Mopar, slowmotion and SS327 like this.
  23. HOTRODPRIMER
    HOTRODPRIMER
    S**** aluminum now. HRP
