is this a good engine/tranny combo?
Discussion in 'The Hokey Ass Message Board' started by olskool34, Sep 13, 2009.
  1. olskool34
    olskool34
    Just heard from a buddy of mine that he scored a 82 mustang 302 and srod ******, 4 spd. and driveshaft. It came out of a 44,000 mile car that was wrecked. He wants to trade it to me from some body parts I have. Would this be a decent drivetrain for a light coupe? Not looking for rip roaring speed and torque here, just a reliable driver. Is there a computer on this engine or just smog ****? Thanks.
  2. temper_mental
    temper_mental
    from Texas
    Put a carburetor on it and go. I would run a 302 good little engine
  3. roughidle
    roughidle
    from iowa
    It's a good combo, you can pull the smog **** off. Those little 302's will take a helluva lot of abuse and keep on tickin.
  4. Old61
    Old61
    from PA
    82-44K don't add up, not saying it isn't.
  5. Great little engine and combo for what you are saying your looking for, you will be happy. No computer, just a bunch of smog **** and equipment. Swap meet a nice carb around 600 cfm, dual plane aluminum intake, some headers short or long, and we will see you smile from here. Someday power aint enough anymore, not hard or expensive to make her a 331 or 347, and still have a VERY streetable low budget runner, good luck with your new mill.
  6. newfalconowner
    newfalconowner
    from NS Canada
    perfet combo, the OD trans is good too,, kinda lack lusting in first, so pick a rear gear suitable (3.50-3.70).
  7. roughidle
    roughidle
    from iowa
    Does sound weird for an 82, but ran across a guy with a 57 Chevy at a local show this weekend with only 69k. All original yet. It happens but not very often. Who knows maybe some little ol lady owned it.
  8. Ebbsspeed
    Ebbsspeed
    I've got a 1956 Chrysler New Yorker with just over 47K original miles. Some cars don't get driven much.......
  9. MERC 55
    MERC 55
    It is not so unbeleaveable, I have a 2000 Dodge Dakota that just turned 21,000 miles.
  10. 61TBird
    61TBird
    He did say that it was "wrecked".
    I recently bought an '85 GT Convertible with 67k miles.It also has it's original top.
  11. Depends on how long ago it was wrecked......
  12. bdynpnt
    bdynpnt
    Just make sure its a 302 because between 1980 and 82 they made some 255 c i small blocks and they were in some mustangs and that engine is a pos. it kind of looks like a 302 but has several subtle differences , check the tune up decals under the hood they should tell the engine size . also the 8th digit of the serial number is the engine code . i will research the code for both and post it
  13. bdynpnt
    bdynpnt
    ok if the 8th digit of the vin is either a D or a C it is a 255 c. i. if it is a code F it is a 302 . the problem with the 255 is nothing will interchange other than maybe valve covers and oil pan even the intake is different.
  14. Periah Bon3s
    Periah Bon3s
    sounds like the perfect combo to me!! no chevy distributor headaches, a four speed is always fun, those mills put out somwhere around 190hp if im not mistaken depending on whether its the h.o. 302. but it wont be hard to grab a little more out of it with a good carb and intake combo. perfect for a cruiser or d.d.
  15. olskool34
    olskool34
    it's a 302, it has aluminum ribbed valve covers that say powered by ford on them and the number came back as a 302. Looks like I'm going to pick it up. Oh, the car was wrecked some years ago but has been in the garage because the guy didn't know what to do with it. It still runs and drives but is smashed up.
  16. JeffB2
    JeffB2
    from Phoenix,AZ
    If you have the AOD transmission,the early ones have a lot of issues that need to be addressed before you use it,best to do that while it is out.AOD's if left sitting for an extended period like this has will usually have a problem with the governor sticking and it won't upshift.Installing a Trans-Go Reprograming kit will take care of most of the early AOD weak points,do a real good cleaning of the governor and install the Hi-Rev that comes with the kit.
  17. vertible59
    vertible59
    The S-ROd 4-speed is basically a 3-speed , with the 4th gear being overdrive. They seem to be pretty tough. I abused the snot out of one in an '82 Capri RS with a warmed over 302 and it held up, even in the heavier car. Should make an excellent choice for your application.
  18. olskool34
    olskool34
    Glad to hear someone has actually had a srod, single rail over drive, on here. I have been told both good and bad about it but hell, you can break anything if you try hard enough. It is going in a model a coupe. Planning on a weiand intake/new carb and headers and that's it. Picking up a 66 bronco rear end with a 3.50.1 gear so it should be a nice combo.
  19. roughidle
    roughidle
    from iowa
    Sounds like it will be a great driver. Should get good mpg.
  20. olskool34
    olskool34
    This is what it is going in, my plans are to keep it as is for awhile before it gets painted. Going to make the motor look as vintage as I can. Oil bath air cleaner modified to fit the 4 barrel, ford green engine paint, cloth ignition wires and a power gen instead of the alternator.
  21. newfalconowner
    newfalconowner
    from NS Canada
    cool, great combo for that,,, totally unexpected too, keep it a single exhaust (stealth) :)
  22. olskool34
    olskool34
    Yeah, I want it as stock as possible, gonna add 16's for ride comfort but the rest will look like a car that you just can't seem to be able to place what is different with it. Single exhaust is a good idea.
  23. RUSTALOT
    RUSTALOT
    from GA.
    WOW! Nice car.
