Technical Is this a problem?
Discussion in 'Traditional Hot Rods' started by NB141FD, Apr 7, 2024.
  1. NB141FD
    NB141FD
    While dis***embling my dual Stromberg 97s I noticed that one of the carburetors has some damage to one of the 'tubes' in the air horn section. As you can see from the attached pictures it is the carburetor on the right. Is there a problem with re***embling and running this carb? If so, what would I experience? I purchased both carbs used about 3 years ago and just recently put them on my 1950 8BA flathead. I haven't noticed any negative running problems. Also, if anyone knows, what would cause this damage? Thanks
  2. spanners
    spanners
    My uneducated guess would be someone had it dis***embled and dropped it. If it ran good before, don't worry about it.
    Deuces and Budget36 like this.
  3. SS327
    SS327
    Carburetor termites! Looks like you caught them in time.
  4. Grumpy ole A
    Grumpy ole A
    X2
    Deuces likes this.
  5. NB141FD
    NB141FD
    Thanks guys, I’ll run with it.
    Deuces likes this.
  6. I also see some square notches in one set of "tubes" and not in the other. As long as they are rated to flow about the same, I wouldn't worry too much about the tube top ends. The bottom ends being the same, along with the venturi and ****erflies, is a more important detail.
