Is this dangerous???
Discussion in 'The Hokey Ass Message Board' started by al bundy, Aug 24, 2008.
  1. GreggAz
    GreggAz
  2. 73RR
    73RR
    Four-thirteeen must still working 'in the field' and is correct. Generally, shear failures occur at the ends near the supports and bending failures generally occur in the centre. Is it stronger than a stock shape ? NO. Will it fail before a stock shape? No doubt in my mind. Perhaps one of the currently employed structural or civil engineers around here needs a project to shove through his beam ****ysis programme.
  3. chopped
    chopped
    Has it been on someone's driver for the last 40 years?
  4. Sellers Equipped
    Sellers Equipped
    from San Jose
    Bring my F!@#!ing Burr head back,, If it breaks,, make another one,,
  5. I saw a car at a show about five years ago that had the holes drilled in the axle what looked way too large of a diameter so that no web at all was left where the holes were, and the axle had obviously bent right at one of the holes -- the hole closest to the driver's side spindle. It didn't break at least, but it was bent, and the wheel on that side had a terrible camber problem. It was an otherwise nice car. You could tell the top of the hole sort of squished up like silly putty and the bottom just bent. With no web at all, it isn't an I-beam anymore, and just two thin parallel bars with space in between.
    When I drilled the holes in my axle, I didn't want to lose too much of the web, so I drilled holes that were about 7/8" or 15/16" diameter (can't remember exactly).
    If it's a real forged steel I-beam, and not a cast one, and it's a really light car, it might be okay, but I'd stay off of bumpy roads and check the camber pretty often in case it starts to bend up.
  6. 51 Leadsled
    51 Leadsled
    from NC
    Yea what he said......Whatdever dat means
  7. touchdowntodd
    touchdowntodd
    can i have it? i neeeeed an axle, ill test it!
  8. 51 Leadsled
    51 Leadsled
    from NC
    Ok, thanks, I just pinched a ****on hole in the seat from laughing so hard
  9. temper_mental
    temper_mental
    from Texas
    Is this dangerous??? Only if it fails or bends .
  10. Koz
    Koz
    My friend has an axle done like this on his old flattie powered FED. Its like a flexible flyer but hasn't broke in all these years, (probably from the mid 50's). Would I drive it on the street? Your kidding right?
  11. 296 V8
    296 V8
    from Nor~Cal
    Seriously my thoughts are the axle is fairly safe
    Being into axles like I am, I pay attention to any info I come across.
    I tend to think they are way over engineered in the first place. (see pic of twisted one).
    I think ford built them to handle rougher roads and more weight than they will be subjected to in today’s world.
    Iv yet to see or hear of one that has broken.
  12. Flatman
    Flatman
    It looks a lot like mine. Mine was run under a '55 Chevy for a few years and did all right. I don't think the weight of my Bantam will bother it.:D
    Flatman
  13. DUDE!!! if your where FU#@ing worried about SAFE! then you wouldn't be building a rod would you?
    either PUT IT ON! or go buy a Volvo .
  14. fordf1trucknut
    fordf1trucknut
    I would NOT be very comfortable driving a car that has that axle in it or be be driving next to a car that has an axle with that much of the web removed. Local buckleing would be a big issue with any kind of impact since there is such a long section of unsupported flange.
    It "might" last forever BUT.. it also "might" fail and kill you or someone else. Why risk that if you don't have too.
  15. Bruce Lancaster
    Bruce Lancaster
    The OUTER parts between perch and spindle have had their original heat treatment destroyed and the bending lever arm (there's a better term for that...) simultaneously increased. I think most stress will thus be absorbed in twisting out there, outside the rigid points created by the perches.
    A dropped original axle is sure as hell weaker than a stocker at the ends for the reasons above, and I've never heard of one failing, not even the most horrible blacksmithed ones.
  16. 49ratfink
    49ratfink
    looks incredibly unsafe. bring it over and let me properly dispose of it on ebay .
  17. WTF? If you put it on a fair to medium weight car, she should be OK. If you put it on aheavy weight, she won't be. However, to be absolutely certain, send it to me and Ill check it out by using it on my car first.
  18. racer756
    racer756
  19. Bass
    Bass
    from Dallas, TX
    I know a guy that has a '32 heavy axle that is slotted about like that on his daily driver hot rod, and he hasn't had any trouble with it.
    It's a forging, so it's pretty stout...even with slots cut into it.
    If you're worried about it, have it magnafluxed.
  20. Sellers Equipped
    Sellers Equipped
    from San Jose
    one thing he forgot to mention was the 1000 pound Blower motor sitting right above it...
  21. The "look" is a vestige of early 60's drag cars like the Fiat pictured. Note the motor is set back at least 50% of the wheelbase, leaving very little weight on the front end. Worked just dandy on altered and comp coupe cars, and of course the street rod guys always want to look as cool as the racers, so the "look" wound up on street cars as well.
    I'm not going to say if their safe on the street or not, but there seems to be quite a few more comments on the positive, than the negative.
  22. 60 Belair
    60 Belair
    A buddy of mine had one on his 32 truck he bought you could watch it twist if you turned the steering wheel while not moving. That being said never had a problem with it drove it for over a year like that and sold it the same way.
  23. 1951bomber
    1951bomber
    from atwater Ca
  24. hotroddaddy
    hotroddaddy
    from jax, fla
    Why could`nt you add some metal back ? Maybe some artsy inserts or something that would add a little more strength.
  25. gearsforguts
    gearsforguts
    from temple,pa
    my grandpop spend eight hours on this axle,drag only tho
  26. safari-wagon
    safari-wagon
    Holes are inherently stronger than slots. That axle works on the drag cars, because their real light in front. The more weight you add, the bigger the risk you're taking on the street, unless you can avoid every pothole in the world.
    I'd only run it in 1/4 mile increments or hang it on the wall.
    Good Luck.
