Is this what you would expect to see on a '29 Ford front end?
Discussion in 'The Hokey Ass Message Board' started by drw47, Oct 5, 2012.
  1. drw47
    drw47
    Have moved up to the front end of my Whippet/ Ford Hybred, while I get some machine work done on the engine. Pulled the front wheels and am seeing the outside of the drums/hubs for the first time. Very strange looking ! Is this what you would expect to see on a '29 or so Ford front end ? [​IMG][​IMG][​IMG]
  2. slddnmatt
    slddnmatt
    i had a 33 pickup that had those style drums on it. still have them in the garage. not sure if they were a specific year thing or more so of a certain application.
  3. need louvers ?
    need louvers ?
    '35 drums. Looks like the spindles are '32-'34 and the axle is model "A" along with the spring perches and spring. All pretty typical stuff...
  4. Carter
    Carter
    Spring perches and spindles are 32-34. Drums are either 32-34 or 35. Only visual difference I know of is 35 is machined for a seal on the inside hub bore.
    Sent from my DROID device using the TJJ mobile app
  5. Weasel
    Weasel
    Look like Rocky Mountain brakes to me - made to run cooler on steep downhill roads - had them on my '33 coupe....
  6. 12" dia =32-35
    11" dia=31
    they are cast not stamped so they give you a better break than early model a mechanicals
    do not cut up those spring perches
    if you need to modify them i have 20 model a's that i will give you and buy the 32-34 perches
    tk
  7. Carter
    Carter
    Chances are good it's all 32-4 stuff. I'd guess 33-34.measure the wishbone from perch center to pivot ball center.
  8. outlaw256
    outlaw256
    now guys this is why i love the hamb.you guys know your shit!!
  9. drw47
    drw47
    I appreciate all the info! You guys are a great source of info!
