Technical Is vintique quality slipping?
Discussion in 'The Hokey Ass Message Board' started by Kiwi 4d, Feb 25, 2018.
  1. Kiwi 4d
    Kiwi 4d
    We were having fuel gauge issues and finally tracked it down to the sender in our 32 3W so had to pull the tank to get at the sender and found the little star washer on the end of the float arm had slid off and the float was free to well float. Anyway the pic is of the cap vintique supply to block the return line. 97 strombergs dont need this. Probably 5 yrs and 9000 miles and its junk yeah there is no fuel there but still. 20180226_173718.jpg
    deadbeat likes this.
  2. choptop40
    choptop40
    Yeah , all the China **** , its cheap it doesn't last...
  3. clem
    clem
    What is it made of ?
    A lot of rubber and plastic products don’t like the fuel we have here.
    Has it possibly just perished from the fuel ?
    Dave Mc and egads like this.
  4. A Boner
    A Boner
    The **** from China has been going downhill ever since they layed off the whole 2nd grade.
  5. RMR&C
    RMR&C
    from NW Montana
    Vintique stuff has always been junk, IMO. I refuse to use it.
    Unkl Ian, seadog, 29AVEE8 and 3 others like this.
  6. I've tried finding rubber 'caps' like shown that tolerate fuel exposure and there just doesn't seem to be any out there from any source. Your best bet may be a short piece of fuel line with a metal plug, or solder it closed.
    Hnstray and Dave Mc like this.
  7. HOTRODPRIMER
    HOTRODPRIMER
    It's easy to cast doubt but if you think about it the damn ethanol in our gas is to blame,none of the rubber gas line hoses or rubber parts will hold up for a prolonged period of time with the alcohol in our fuel.
    I have changed all my lines to the lines that are manufactured for cars & trucks that run Diesel fuel,they are resistant to the ethanol. HRP
    Frankie47, Johnny Gee and Dave Mc like this.
  8. Dave Mc
    Dave Mc
    I bought a Pkg. of Chinese Rubber Caps to Block the heater hose outlet on the Ford 302 waterpump , they suffer the same way with water / anti-freeze as with the Ethanol Fuel , **** crumbles and cracks in about a years time, Most Auto Parts Stores only have that junk on the shelves
  9. X38
    X38
    I've seen the rubber boots on new tie rod ends split and crack on project before they even hit the road. Manufacturing source as above.
    Their 'rubber' must be the same as their 'metal.'
    V8-m, Unkl Ian, RICH B and 2 others like this.
  10. HOTRODPRIMER
    HOTRODPRIMER
    Ethanol dissolves rubber from the inside out. HRP
  11. Kiwi 4d
    Kiwi 4d
    This fitting is out of sunlight and is a cap for a non used fuel return line . I suppose when the tank is right full a little fuel could slosh up the return line. But this is cracked from the outside.
    I know exactly what HRP is referring to ,we have triple carbs on a Y block that has been sitting out of the car for maybe 5 yrs the rubber ?? Lines are dangerous now hard and brittle.
    HRP is there a specific brand of Diesil fuel line that you use?
  12. Blue One
    Blue One
    from Alberta
    The37Kid and KoolKat-57 like this.
  13. HOTRODPRIMER
    HOTRODPRIMER
    I get the hose at NAPA,it's composition is Nitrile Tube,For Use With Leaded and Unleaded Gasoline, Ethanol and Methanol Based Gasohol and Diesel Fuel.
    It's about 35 dollars for a 20 foot roll. HRP
  14. Blue One
    Blue One
    from Alberta
    Product name or manufacturer name or part number Danny?
  15. Hnstray
    Hnstray
    from Quincy, IL
    With high volatility chemicals even the vapors are very destructive....
    Ray
  16. Kiwi 4d
    Kiwi 4d
    "Long Life"be ******ed. Replaced fuel lines while tank was out. 20180228_142510-1.jpg 20180228_142443-1.jpg
  17. Kiwi 4d
    Kiwi 4d
    Unfortunately we dont have a napa down under. The local parts house has gates fuel line.
  18. Beanscoot
    Beanscoot
    I have given up on parts store caps, and now I collect them from the junkyard. 20+ year old stock pieces are much better than the parts store pieces, sadly.
    I see that some vendors are selling Hypalon caps, maybe they are better. I have successfully used hypalon rubber cloth to make fuel pump and accelerator pump diaphragms.
    Truck64 likes this.
  19. tomic
    tomic
    it's american companies, brand names, and importers that are the problem. those are the businesses spec'ing **** parts to sell with a brand name on it. once-good brands like Fram are the problem, importing low grade failure-prone **** and relying on past reputation to sell it. "china" can make good stuff, but quality parts requires the feedback-loop of quality control, fix design flaws, pay more for better materials, etc. cutting corners to make a buck is the problem. good stuff costs more no matter who makes it.
  20. The37Kid
    The37Kid
    Didn't Randy's Roadster fire start because of a rotted gas line? I think about him and his Roadster every time this topic comes up. Bob
  21. Beanscoot
    Beanscoot
    The frustrating part of this is that caps made of really good rubber might have what... an extra five cents worth of material?
    So just sell the durned things for fifty cents more. I would be happier to pay $5.50 for a handful of best quality caps than $5 for poor quality ones that last a fraction as long.
    But we usually have no way of knowing what quality we're buying. Even if one could find "the good ones" today, next year the same package may well have **** in it.
    Kiwi 4d likes this.
  22. tomic
    tomic
    damn. yeah, fuel (and other) hoses are a particular form of hell these days. i try to buy good ones. i'm buying "ordinary" stuff from Summit more and more, cuz there's fewer parts stores these days. local NAPA closed a year ago.
  23. Fortunateson
    Fortunateson
    In in a large urban area there is probably a firm that deals in all types of rubber parts for industrial applications. The one near me, I’ve forgotten the name at the moment but it will come to me around 3:00am PST, always has what I need. When I ask for two or three they insist on giving them to me and I insist on adding to their beer fund. Nitrile, viton, etc. all available. Now if you are at someplace like Dogpound, Alberta you may be in for a bit of a drive!
  24. 28 Ford PU
    28 Ford PU
    from Upstate NY
  25. lonejacklarry
    lonejacklarry
    I have solved the problem, at least to my liking: I buy ethanol free gasoline. It costs about .40 a gallon more around here and it is available a lot of places. Yes, it is more expensive but changing out gas lines is a ton of work. It solves the problem for winter storage, too.
    Now if I had a BBC in a daily driver it might be different but I don't. Putting the arithmetic to it: 5,000 total miles a year on three hobby cars (5000 / 15 mpg x .40 = $133) per year extra for ethanol-free gasoline. I don't have a lift and changing gas lines troublesome for a person with ***anium knees.
    And the worry about leaking fuel lines because of ethanol is gone. See: https://www.pure-gas.org/ for more info.
    I use it in lawn mowers, and other lawn stuff as well as my tractor.
    Gman0046 and 28 Ford PU like this.
  26. samurai mike
    samurai mike
    I've had wiper blades fail in less than a year on a few vehicles. just ****py rubber these days I guess.
  27. 28 Ford PU
    28 Ford PU
    from Upstate NY
    I totally agree. My neck of the woods the non-cornoil is 93 octane and .30-.40 cents a gallon more also. I couldn't believe how much better the Rod fan and gas mileage shot up too.
  28. 28rp
    28rp
    The return line rubber cap degraded on my Vintique Tank sender in a couple of years-no fuel in the vicinity-ever...
  29. Lone Star Mopar
    Lone Star Mopar
    Doesn't have to be exposed to fuel at all, the rubber quality is garbage currently. Ive had suspension bushings, tires, vac*** caps all go bad in short order recently.
    Sent from my SM-J727T1 using The H.A.M.B. mobile app
    Truck64 likes this.
  30. tomic
    tomic
    most of my driving is long distance road trips, mostly southwest desert. i have to buy, and run well, with whatever **** gas i can find. (literally yesterday, the drive from Ely NV to Tonopah NV, 150 miles with no gas stations, fill up at each end.) home (los angeles) i tune and drive for the cheapest possible (CA spec fuel isn't bad) then on the road buy middle-grade. i keep spark set back 2 degrees more than i'd like but it means i never have ping problems.
    i replace fuel line every couple years, without even checking it. i have a pusher electric pump back by the tank with a cheap canister filter, when i change that filter, i change those hoses. same under the hood.
    i'm using fuel line for emissions/vacuum hose (PCV and vacuum wipers). it's just easier to have only one type in my shop.
    i'm with Lone Star Mopar. all "rubber" products today ****. it's not even a money thing. if anyone can point me at a good brand i'd appreciate it.
