Technical Isky cam I.d?
Discussion in 'The Hokey Ass Message Board' started by carpunk, Sep 24, 2019.
  1. carpunk
    carpunk
    Not sure what this fits or anything about it
    Can somebody clue me in please just going around in circles online
    End of cam says
    TY83A
    ISKY
    3P 112
    256 HYD
    SUPERCAM
    396
  2. FritzJr
    FritzJr
    Maybe it's a hydraulic cam with 256 degree duration and 112 degree lobe separation that fits a 396 BBC.
  3. carpunk
    carpunk
    Well I thought that but I can't find anything online so never ***umed and I did see something relating to amc and as I have no gm stuff it doesn't look familiar to me plus it came from a jeep guy
    So whats the lift and spec?? Maybe I can trade it with somebody for a ford cam
  4. FritzJr
    FritzJr
    From the Isky website:
    • Performance-Economy Supercams™
    • Hyd.
    • Valve Lift Int/Ext. 0.425
    • Valve Lash Hot Int/Ext. 0.000
    • ADV Duration Int/Ext. 256
    • 0.050 Duration Int/Ext. 202
    • Lobe Center 112
    Product Features:
    • RPM-Range 1500-4800
    • 1.5:1 Rocker Ratio
    • Grind No./Type 256-Supercam Hydraulic
    • Best Torque And Economy In P***. Cars And Trucks
    • Max Compression 9.5:1
    • Smooth Idle
    • Standard Axle Ratio
    • Good Vacuum
    • Computer Compatible
    • Standard to 600 CFM Carb
  5. Penetrator
    Penetrator
    from SK CAN
  6. carpunk
    carpunk
    Where's the part numbers I posted on theyre site to confirm it??
    What am I missing here?
    I was actually on that site looking at that cam before i posted . Ok so it's not a BBC cam then it's Pontiac? Glad i never ***umed !
    3p?
    TY83A?
    Sorry if I'm ignorant on this but its listing a 4.9 AND 7.5 is that even the same block and would fit??
    Thankyou for taking the time to try and advice but I'm still not entirely convinced I
    Might just call them today
  7. treb11
    treb11
    Pontiacs all have the same dimension for the cam, so they fit all blocks/displacements. There is no such thing as a "big block" or "small block" Pontiac.
    Like you, I don't see the tie-in determining it is a Pontiac cam. A call to Isky should reveal all.
  8. BamaMav
    BamaMav
    from Berry, AL
    Call Isky, they have records going back for years. A cousin of mine has a nailhead Buick cam that he got in some parts he bought, couldn’t find any specs on it. Called Isky, it was a one off that had been ground for a racer, they tried to buy it from him! He put it in his nailhead in his 59 Chevy pickup, he really likes it!
    carpunk likes this.
  9. carpunk
    carpunk
    Ok SO!
    Isky says it IS a big block Chevy camshaft
    Partnumber 396256
    The TY83A is a build date code
