Projects ISO 331 hemi long nose roller cam
Discussion in 'Traditional Hot Rods' started by moparob, Apr 14, 2020.
  1. moparob
    moparob
    Can’t post to the classifieds for some reason so I’ll post here.
    Like the title says I’m looking for a 331 hemi long nose roller cam. I have seen lots of short nose 54 and later Cams but I am specifically looking for the 51 to 53 long nose variety in roller lobe trim. Let me know what you’ve got.
    Pic for your attention and what it will go in.
    [​IMG][​IMG]
    6sally6 likes this.
  2. moparob
    moparob
    Bump
  3. 41rodderz
    41rodderz
    from Oregon
    Moderators will be along shortly to push over to over to the want ads.
  4. tubman
    tubman
    Do they even make them? I would think that they did back in the day, but they have to be few and far between these days. What would it take to convert your engine to use the later cam? With a car like that, you should use an aftermarket aluminum timing cover anyway.
    With the '54 short bell in my dirt car, I went to an aluminum front cover and intake manifold and took 75 lbs off of the front of the car. It allowed me to eliminate a serious "push" problem the car had.
  5. gimpyshotrods
    gimpyshotrods
    You cannot post to the classifieds from the phone app.
    You need to be on a regular computer.
  6. George
    George
    Why? It not like anyone is going to see it.
  7. willys36
    willys36
    You can use a later model 331/354 short snout cam in your hemi. I forget exactly what I did to convert mine (was 45 years ago!!) but it was simple. I think I got a conversion kit that consisted of a spacer washer the thickness of the cam retainer plate and a 354 timing chain set.
  8. 73RR
    73RR
    ...I've got one in the discount bin.....
    Hnstray likes this.
  9. George
    George
    The spacer is for using a LA timing chain/gears. A 354 cam & OEM timing set up should be a bolt in.
    gimpyshotrods likes this.
  10. 73RR
    73RR
    ...still available for anyone interested.
