It needs a lot more than a regular tune up..
Discussion in 'The Hokey Ass Message Board' started by HOTRODSWE, Apr 28, 2009.
  1. HOTRODSWE
    HOTRODSWE
    See my other post of my last buy here:
    http://www.jalopyjournal.com/forum/showthread.php?t=356670
    I did mention that it didn,t run good, however after spending a day searching for what belive was a missfire issue i did check the compression on the cylinders, and it turn out that no3 was reading zero! OK no way back the motor has to be turn down.
    Guess what I found......
  2. SHRUM
    SHRUM
  3. flatheadpete
    flatheadpete
    from Burton, MI
  4. Fenders
    Fenders
    No piston, no rod....?
  5. billbrown
    billbrown
    swedish fish in the oil pan. Those are a pain in the *** to get out of the carpet let alone a motor.
  6. BangerMatt
    BangerMatt
  7. SHRUM
    SHRUM
  8. r8odecay
    r8odecay
  9. Pir8Darryl
    Pir8Darryl
  10. HOTRODSWE
    HOTRODSWE
    No sorry, your all wrong
    The valve seat was missing!?! (I had take out the valve on the picture?
  11. Bruce Lancaster
    Bruce Lancaster
    Look for simple first...a common problem with L head engines left sitting too long is a valve sticking open. Have someone rotate engine while you peer down #3 sparkplug hole. If you see a valve stuck open...try just oiling it and tapping it down, rotate and repeat til it oils up. Zero rather than just a poor reading usually means something simply not moving.
  12. Bruce Lancaster
    Bruce Lancaster
    Holy Cow! REALLY gone, no sign of broken pieces?? Also may well mean you have a later, maybe mid 1930's built banger...I think before '34 or 5 no seats unless put in for a repair.
  13. HOTRODSWE
    HOTRODSWE
    Yes most of it are gone, some small parts stuck in piston and also in no4 cylinder but no major issue with the pistons, overall the motor seams overhauled sometime with new pistons and so on, and the valve seat is a poor repair, the motor is a 32 motor. someone have tried to secure the valve seat with some punch marks that maybe cracked the seat?
  14. r8odecay
    r8odecay
    Now that you say that i can see the peen marks in your first pic...
  15. HOTRODSWE
    HOTRODSWE
    The plan is to make a cutting tool to reshape the hole perfect with the motor stillin the car and not taking it apart, and then make another seat and press that in place, fine tune the seat and install a new valve and then it,s good to go...
  16. Mike51Merc
    Mike51Merc
    Some guys stake them in with pins. There are also some hi-temp adhesives out there that may help. You could buy oversize seats, but you'd have to have the block machined to fit them.
  17. HOTRODSWE
    HOTRODSWE
    A tool is made for cuting a new seat for the new seat.....
    Here we go
    And finally a fresh seat ready to take a new seat
