IT REALLY WORKS, BB,s in tires
Discussion in 'The Hokey Ass Message Board' started by yblock292, Jun 6, 2010.
  1. yblock292
    yblock292
    Running 4.75 16's on my roadster (avatar) could never get them to quit bouncing over about 50 MPH, I even sent them down to the hot rod garage in sands springs Okla. and had them shaved, balanced with all the latest and greatest equipment, talked to Coker last week about replacing them,and as normal the great customer service we get from them, "not a problem" even though i have had them for almost 3 years .So just for fun yesterday i got 2 12 guage shotgun shells with #9 shot, took the valve's out of the valve stems, dumped 1oz of shot in each tire, took her out for a spin.At first no change the all of a sudden, NO FRIGGIN BOUNCE! drove her to Delano yesterday up the highway, 60-70MPH smooth as silk. She will bounce for about the first few miles then its done, unbelievable the differance it made!
  2. troylee
    troylee
    I use to put Balancing sand in big truck tires. I would roll up into balls and balance them. A wile back a guy was selling a ring that fit between the wheel and drum. Had a ring filled with oil a ball bearings, said to do the same thing. I would wonder how many miles or at all if it would damage the inside of the tire?
  3. yblock292
    yblock292
    I don't think it will, got tubes in them and once they find their "sweet spot" they stay there.Its really a kool deal.
  4. temper_mental
    temper_mental
    from Texas
    I use the ceramic balancing pellets in my wheels works great!!!
  5. clifforddean
    clifforddean
    We sell a product at our truck tire business called equal balancing compound and never had a problem with casing damage with use. It mainly gets used in steer tires then when they're worn out we retread them for drives or trailer use and never had reject because of the compound. I've even heard of guys puttin a couple of golf balls in there. It comes in paper bags that open when it rolls, each tire size has specific ounces for use.
  6. JohnEvans
    JohnEvans
    from Phoenix AZ
    All the tire balancing in the world won't help if the drums/rotors are out of balance. That's where the beads etc. come into play ,they are taking care of the imbalance in the drum/rotor. Use to be you could get the whole shooting match done on the car taking care of all the prob. That kind of equipment is about as hard to find as a Dodo bird. Only know of one place in Phoenix that still does it.
  7. If they are bias plys the first few miles is probably working out the flat spots from being parked the tires get warm and become round again.
    Never tried BBs but I guess it would work. I have liquid balanced a bunch of them like they used to do with the big trucks should work on the same principle.
  8. VenomousType
    VenomousType
    from Atlanta GA
  9. News flash here as well! WOW! Just to keep us from being arogant asses!
    Please! may I have another boss!?!
  10. 69fury
    69fury
    looks like someone needs another....he wouldn't want to be (more of an) arrogant ass...
    To the OP, I've used the powder before, but never thought of the bb's..
  11. big creep
    big creep
    yea i use to buy the sand bags for my 4x4 back when i had 44 inch tires. it worked great!
  12. wizzard23
    wizzard23
    Y-Block, think this would be worth a try on some 145 tubeless radials? I've got the same problem on my roadster.
  13. yblock292
    yblock292
    Do it you wouldnt believe it , getting ready to go drive the roadster to get something to eat and prove it to myself again..........
  14. AstroZombie
    AstroZombie
    In the 4X4 world the guys use airsoft pellets in their tires. Never thought of adapting it to a hot rod! Good find!
  15. Lostj
    Lostj
    from Miami, FL
  16. yblock292
    yblock292
    ok girls and boys i had to go prove it to myself again................un-friggin believable ran it up to at least 75 mph ( no speedo) smooth as hell it has never driven like this in all the years i've owned her, find a skeet shooter, they use #9 shot, a normal 12 guage holds 1 1/8 oz of shot, open up the top of the shell, take the valve out of the valve stem and pore it in, gonna spill some so about an oz does it.
  17. pdq67
    pdq67
    Back, years ago, W/JCW sold tire balance disc's that mounted between the rims and the drums that did just this w/ ball bearings in their OD tubes.
    Not new tech at all by me.
    pdq67
  18. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    so how does this work, do the BB's keep moving around or do they imbed themselves into the light side of the tire??
    Dont quite understand the concept of how this works. (wish I had heard of this when I had my sedan with bias, had them shaved on the car which worked but this is interesting and might be necessary for my next set.
  19. rob lee
    rob lee
    from omaha,ne
    I had my 15' front runners shaved,balanced and they were better.I think I'm gonna give this a try to get rid of the little jitter i get at 60+ mph. Smooth as silk sounds good! Oh yea they are coker stones 5.60 15
  20. howco
    howco
    Learn something new every day, still thinking about how it works though???
    Not making sense to me....
  21. r8odecay
    r8odecay
  22. Butcher Boy
    Butcher Boy
    Dyna Balls rule !!!
  23. Dirty2
    Dirty2
    Good info !!!
  24. yblock292
    yblock292
    Its Hot Rod magic!
  25. Anderson
    Anderson
    Used Dynabeads in my modified from day one, mostly because I didn't want half the rim of my wheels covered in lead weights. They worked perfect.
  26. Whoa. I learn something new and awesome everyday here.
  27. cracker head
    cracker head
    I got them in my '32 as well as my motorcycle. I will continue to run them in everything I own.
  28. 454navyss
    454navyss
    interesting, ill have to keep this in mind
  29. gimpyshotrods
    gimpyshotrods
    I run ceramic ones in everything I have on the pavement, and have for years.
    Every so often somebody notices that my DD, which runs bias 36's, has no weights whatsoever.
    Not sure about steel though. Might have a rust issue over time.
