Hot Rods Its Alive! My AV8 Coupe is on the road!
Discussion in 'The Hokey Ass Message Board' started by Tank, May 14, 2011.
  1. Hitchhiker
    Hitchhiker
    I gotta ask....How is the angle of the steering wheel?
    also do you have a drop axle?
    Never mind on that drop axle..... 4 inch MorDrop
    Do you have a dropped upper steering arm?
    thanks
  2. roseville carl
    roseville carl
    Congrats on getting it on the road "Henry" is proud of you now enjoy it.....
  3. I like it the way it is!
  4. sololobo
    sololobo
    WoW, great looking "A", nuthin like blastin down the road in a v/8 hot rod. Congrats bro!! ~sololobo~
  5. 40FORDPU
    40FORDPU
    A long time to stay with a project, good for you to not give up on it. Looks great.
  6. Gromit
    Gromit
    It's great as is. A chop would look cool, but it's also cool to see one un cut now and then. So long as you are enjoying it mate!
  7. Jalopy Jim
    Jalopy Jim
    Looks great just the way it is. Drive and enjoy.
  8. Pete1930
    Pete1930
    from Boston
    That is sweet, man, great job! I love the way it looks, and mine will look similar. I'd leave it just like it is. Mine will probably take just as long.
    Pete
  9. VanHook
    VanHook
    Great job man, it looks great, wish mine was on the road!!!!
  10. ct1932ford
    ct1932ford
    5" no problem! Here is an A I did 4-1/2" Either way nice ride and Good Luck.
  11. Barnmiester
    Barnmiester
    from wyoming
    Killer car man! Drive the **** outta her while you can, then maybe in the winter months chop her. Either way cool car
  12. Tank
    Tank
    I put the seats I was going to use in my car and sat in it with the wheel and column i was planning on using ('36 banjo and column). I left the steering box and "A" flange not welded so I could tilt it to where I liked, and tacked it, I then made a column drop that bolted to the original "A" column drop on the bottom of the tank. My angle is pretty much the same as an original "A". If you dont drop it down and bolt it to the original spot its at some stupid T-Bucket looking angle.... I'll take a picture and get some measurements on the drop for you.
    My upper steering arm is not dropped. Its just a standard old school hoop style one. With my axle being a '40, the drop of the axle, and using the model "A" perches. A '40 is wider at the perches. I couldnt use a dropped steering arm. I do have a bit of an angle on my drag link, but have had no issues with bind or anything, and almost no bump steer issues with it either.
    Hope this helps you man! Anything I can do, let me know.
  13. MR. FORD
    MR. FORD
    from Austin, TX
    Im on board with these guys.....Great job!
  14. -Brent-
    -Brent-
    Hey, nice work Tank. How about some detail pics?
  15. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    Looks like we are building exactly the same car! Im still torn on chopping it. I know if I parked it down the street it would look too tall but sitting in my back yard it doesnt look that bad. The only things non ford V8 on mine so far are the rear end, T5 trans and the mini van seat, other than that its all pre-war ford iron.
  16. Very cool car! I really like everything about it!
  17. Tank
    Tank
    Thanks everybody! I'll post up some detail pics as soon as I get a chance. Been straightening out some wiring issues, and some other little things. Mainly having fun driving it though!
  18. greaser
    greaser
    I like it without a chop. Maybe just run it for a while the way it is. You can chop it for a new look when you get bored with the look and want something different.
    Build it the way you want...it's your time and money.
  19. 32SEDAN
    32SEDAN
    Looks great the way it is or you could chop it 9" and wear goggles as your head will stick out the top...
  20. Southfork
    Southfork
    What did you use for the center crossmember? I can see it sitting lower than the rails in your pictures.
  21. Hitchhiker
    Hitchhiker
    Thanks Tank, looking at pictures of your car is great inspiration for me.
  22. Fordtudor37
    Fordtudor37
    Why be a sheep and follow the crowd ? - DON'T CHOP IT AND BE DIFFERENT !
    Nice looking ride !
  23. shane85
    shane85
    nice work man. i dig it!!
  24. aldixie
    aldixie
    Love the car, congratulations. Hoping to get mine on the road next year.
  25. 68hillbilly
    68hillbilly
    from KENTUCKY
    Love dem a models
  26. Tank
    Tank
    Thats a home made center crossmember I made out of some 7gauge sheetmetal. I braced it up real good in the areas that I mounted my front wishbones to before I boxed it in. I also have my trans mounted to this also. Seems to be working pretty good so far! I have some pics of it somewhere If I can find them
  27. 73azza
    73azza
    Awesome! Just how I like it!! Nice Job.
