It's BONDO time!
Discussion in 'The Hokey Ass Message Board' started by Paul, Dec 22, 2003.
  1. old beet
    old beet
    I love that porthole!!!!......OLDBEET
  2. fab32
    fab32
    Paul, I guess its time to tell you once more that your car has got that "SOMETHING" that just screams HOT ROD. From the first time I saw it it sure turned my crank. I think its because its like a fresh creation, its not copying anything. That and the fact it just says "EVIL" makes it unique.
    I'm going to reserve judgment on giving it the FINISHED look and hope it doesn't lose any of its CHARACTER.
    Frank
  3. MercMan1951
    MercMan1951
    Paul, that's a good point about the heater. I have a gas wall radiant unit, and I was wondering about the flammability of the dust. I normally do my bodywork when the weather permits keeping the garage door open, but I may get in to some filler work before spring.
    Anybody ever hear of filler dust causing a fire? I have this image in my head of the dust filing the shop and then spontaneously ignigting into a flash over or something because of the open flame of the heater. Is filler THAT flammable?
    Love the ride, by the way. But you already know how we feel about that!
  4. Paul
    Paul
    Editor
    [ QUOTE ]
    when plastics burn they produce toxic gasses that your mask will not stop...
    [/ QUOTE ]
    Like hydrogen cyanide and dioxin to name two.
    I wouldn't worry about explosive dust, it is the dust burning in the heater and letting off toxics into a confined space that scares me.
    I just try to keep the airborn particles to a minimum and use plenty of ventilation.
    Paul
  5. Rooster
    Rooster
    For a few dollars more, My Dad has gotten dust collector compatible tools that he uses now. Orbital Sander(DA) and mostly wood tools. I've wondered what a long- board would look like with dust collector on it. Haven't seen one. But I'm bettin they're available. I should ask my buddy who worked at the limo mfg'r. Bet if anybody knew, he would.
    Very Good point on the toxicity of burnt plastic dust.
    I'll add my Love of yer car to this post too, since I've never said it before. Love that thing! Makes me wish my project rod wasn't a sedan sometimes... The awesome job you did on the shape of the whole tail and it's relation to the wheels with those reshaped arches is as Cool as how you did the grille to not look awkward like so many Mopars do... Can I just say I LOVE it?
  6. plmczy
    plmczy
    Nice work and thanks for the tips. I have one question, What brand tires are those on the back of your car? I want to run a set of cheaters on the back of my Dodge but PA inspection rules says you have to have tread. BF Goodrich drag radials are OK to use here and I took notice there are 2 tread grooves in your tires, so they would pass. later plmczy
  7. Paul
    Paul
    Editor
    plmczy,
    they are Radirs and they will add grooves for a little mo bux,
    but, they do say right on the sidewall "Not For Highway Use" though..
    Paul
  8. Just Gary
    Just Gary
    60's Style,
    You applied the bondo on top of primer? Wouldn't it stick better if you stripped all the old primer off? [​IMG]
    Not trying to rain on your parade... I love the car! But I'm planning to do some bodywork for myself soon and want to learn everything I can before starting.
  9. Paul
    Paul
    Editor
    gary55,
    The primer is relatively fresh DP90 epoxy over sand blasted steel.
    Manufactures suggested application says; primer, filler, surfacer, sealer, top coat.
    Most body men I've talked to do like to put the filler on bare metal though.
    Paul
  10. Just Gary
    Just Gary
    Thanks much; for the tech post AND the clarification. [​IMG]
  11. Rooster
    Rooster
    Perhaps you could add an answer that's plague me a long time too!?
    They say to only put the epoxy on bare metal, not over your filler mat'l. So what're ya supposed to do to get an even epoxy coat after ya sand it down and expose metal around the mud? I've always just spot epoxied without trouble so far, but always wondered if the epoxy's were actually bonding together or leaving a small gap at their seam?
  12. overspray
    overspray
    OK--Here's the gospel on filler over primer. I used to work as a technical/sales rep for the company that makes rage. I know the guys (chemists) that developed the resin for rage filler. I've been a bodyman/painter,sales rep and technical rep for 30 years. The resin in rage and other body fillers is fiberglass (polyester) resin. Today's resin technology makes the adhesion of these new resins as good or better than most epoxy adhesives (glue). They are designed to really stick! Also they are somewhat flexible when used properly. Most or probably all filler manufacturers design and reccommend them to be used over clean and prepped (grinding with course-36 grit) and rust free (sandblasted)and dry (free from moisture) BARE metal. They will stick to epoxy primers with mechanical adhesion-they DO NOT chemically bond with epoxies. If you put filler over epoxy primer it has to be fully cured with no solvents (thinner-reducer) left in the primer and still should be sanded with a course grit and cleaned. In other words- It's a wasted step that may or may not cause adhesion problems later on. Most critical is to be clean and moisture free. Body filler resin is a thermal set plastic-it cures with heat. The hardner-MEK peroxide is a catalyst that produces heat in the resin. It needs to be at 64 degrees F to cure-best is 72-80 degreesF. (If you live in a warm climate still read on but it may not apply to you.) If the metal is cold the filler will cure from the outside in and could trap some moisture and solvent from the resin underneath-causing adhesion or bubbling problems later. (Styrene is the solvent in resin and produces the smell we****ociate with bondo and fillers). Also moisture (humidity in the air) will condense on the surface of the cold metal. This is the same effect you get when the mirror in the bathroom fogs up when you shower. (I hope you all shower). The mirror and the metal of the car are about 10-15 degrees cooler than the air temperature and the humidity condenses on them. If you warm the mirror or the car metal to about the air temperature, the moisture won't condense on the surface. Using a heat source to warm (NOT HOT) the panel will eliminate the moisture being trapped under the filler (which can show up as rust under the filler) and help keep the cure temperature even through the filler. This is the way the chemists designed the product to work. You can use extra catalyst to speed the cure, but too much will cause too much heat in the reaction and crystalize the resin which causes it to be brittle and break down (yup-more problems later). If you head to the autobody supply store for more hardner you may be using too much and looking at problems down the road. PreWARMING the metal and keepin the shop warm will let it cure more evenly with the correct ammount of hardner. Heat lamps or lights should be far enough away so the panel feels warm when you put your bare hand on it (NOT HOT). The correct ammount of hardner is 1 1/2-3%. Here's an easy way to figure it. On the pallet or board you mix your bondo or filler on put the amount you are going to mix up in the form of a circle. With your spreader or mixer divide the circle in half-50%. Divide the half in half-25%-half again-12.5%-half again-6.25%-3.125% (this is the maximum) half again-1.5% (this is the minimum). If you have a COLD shop put a small batch on a WARMED test panel to check the cure-spread to about 1/4 inch thick. After a few times you'll be able to gauge the amount for the size of the filler batch you are mixing. There is some room here for a little extra-but not a lot of extra hardner. REMEMBER, this needs to work with the temperature of the air and metal. It will cost a lot less to follow these steps of correctly preparing the metal and working with the correct temperature range and hardner amounts than to even bother with epoxy primer as an underlayer. Between coats of filler DO NOT wipe with solvent (thinner). Rough up the areas not sanded and blow the dust off real good then apply a new layer. (Solvent will absorb into the filler). Thickness of the layers should not be more than 1/4-3/8 inch. If you put filler on too thick the heat in the reaction will be concentrated and higher in the thick area and could lead to crystalizing the resin in that spot making it brittle and subject to cracking later. Also too thick can mean you won't be able to get all the air pockets smoothed out. Use a primer surfacer system that is reccommended for the paint you will use. Self etching primers usually contain an acid and should not be used under filler ( the acid will slow down thew cure of the resin). I like these for bare metal on my projects. I use them but grind them off where I do filler work. Also the acid in self etching primer will affect the epoxy resin hardners in epoxy primers where they may not cure chemically but will still dry. It is possible to put epoxy primer over self etching primer BUT ONLY if the acid is gone and the etch primer is fully cured. (probably a wasted step anyway). My preference is etch primer on bare sandblasted metal (I'm talking old cars here) bondo or filler on bare metal, a catalized spot or glazing putty (bondo skim coat), a good 2 part urethane primer filler and a good topcoat finish. Yup, I know how to make paint look like primer (suede). Now one more thing to screw up your minds-- today's bondo/body filler technology will adhere to properly cured paint and primers if they are absolutely clean and dry. They stick by mechanical adhesion- they grip to scratches-the rougher the surface the better the grip. Solvents (thinners and reducers) in paints and primers can work under the edges of the bondo/body filler area-and it's easier for this to happen if you have paint or primer under the bondo/body filler. Even when priming over filler on bare metal don't put so much on that you have the solvent affect or "lift " the edge of the filler. Use nice even coats and let the solvents "flash" (evaporate) between coats of primer. (no bondo work today-- it's 25 degrees below zero Farenheit I'll be spending most of the day trying to find IT to pee) overspray
  13. Paul
    Paul
    Editor
    thanks overspray,
    some good info there.
    sounds like I'm on track with all except,
    I did wipe my epoxy primer down with laquer thinner before and after roughing it up.
    but I did blow it all down good with clean dry air and brought it up to room temp before the filler went on.
    this will only be my third complete paint job, 'still learning [​IMG]
    the first two turned out ok..
    Paul
  14. overspray
    overspray
    We're all still learning (I hope). I just wanted to pass along some good info. I'm not into putting anybody down. I really like your ride. Looks like you are doing GREAT!! From the looks of the numbers viewing this post there are a lot of people interested in your car and BONDO. Keep the progress pics coming. overspray
