It's Easy tech and garage tips time again.
Discussion in 'The Hokey Ass Message Board' started by Smokin Joe, Sep 14, 2004.
  1. Canuck
    Canuck
    No great technical knowledge here, just a safety idea. Fire extinguisher mounted on the Mig cart, always handy where the hot stuff is.
    jim
  2. Got a stripped out hole in a piece of wood?
    And even a sheet metal screw won't hold?
    Get a bottle of Cyanoacrylate glue at the hobby shop.
    Goldberg's works fine. (The one you want is the thin watery stuff.)
    Sand up a little pile of sawdust from any old piece of wood.
    Makes no difference what the wood type is.
    Pack the sawdust in the stripped out hole.
    Apply 2-3-4 drops of the Cyano glue to the sawdust.
    This turns the sawdust in the hold and the surrounding old wood very hard.
    Drill a hole where required, screw the part down using a sheet metal screw and you'll have a fix that's stronger than the original and long lasting as well.
    (In lieu of sawdust you can use baking soda, but it comes out way harder than the sawdust - not sure about how long the fix will last with the baking soda, but it does work. Either the sawdust or baking soda will make for a hard to sand surface so mold the dust or soda close to where you want it when dry.
    A quick and easy temporary fix - that can last a long time - for a stripped out sheet metal hole that won't hold a sheet metal screw:
    Get a paper clip, bend a short section into a very tight "U" shape.
    Drop the short piece of paper clip into the stripped out hole.
    Install screw.
    It will hold about the same torque a fresh sheet metal hole will.
    This works cuz the paper clip piece forces the sheet metal screw to bite into fresh sheet metal. [​IMG]
  3. flamedcoupe
    flamedcoupe
    When I wire a car I always run the new wires all the way to the tail/parklight socket. To make a new contact point on the end of the wire I skin about a 1/16 of a inch of insulation off then bend down the ends 90 degrees and in a circle than drop on a drop of soder. Makes a good contact point for the bulb and wires are color coded all the way to the light housing.
  4. CptStickfigure
    CptStickfigure
    from Urbana, IL
    [ QUOTE ]
    [/ QUOTE ]
    If you don't need a superglue-strength fix, just coat some wooden toothpicks with wood glue, stuff them down in the hole, and break them off flush.
    I used to do that for things like guitar strap locks and it worked fine.
