it's HYDRO-MATIC. . . .
Discussion in 'The Hokey Ass Message Board' started by lincolnlog, May 29, 2007.
  1. lincolnlog
    lincolnlog
    from Arizona
    hello guys, i was poking around under the carpet on my ride and found the trans dipstick. Looks like the oil is a bit low, what fluid would you recommend. looks like it has red stuff in it now.
    thanks.
  2. yorgatron
    yorgatron
    i've used the dexron and i've used the type F.
    type F hooks up a little better.
  3. lincolnlog
    lincolnlog
    from Arizona
    I think i will use dex, that is what it appears to have in it. does not look burnt either. I know that the trans was rebuilt in 02?
  4. UnsettledParadox
    UnsettledParadox
    type F is typically used in ford transmissions. they require a little bit different mixture hence the good "hook-up". anything else takes dexron
  5. DE SOTO
    DE SOTO
    Its actually HYDRA~MATIC
    unless of course its full of WATER :D
  6. Brandy
    Brandy
    from Texas
    Hahahahaha..........:D
    Dexron is what you should use. Smell it, taste it, roll in it. It'll become your new best friend.
  7. petebert
    petebert
    it originally called for Type A, did F supercede that? Dex III is what people say to use and it is supposed to supercede F. Do not use Dex V
    The old manuals also says that in an emergency you can use motor oil!
  8. DEXRON III (and it's predecessors) replaces TYPE "A" and TYPE "A" SUFFIX "A".
    Nothing supercedes TYPE "F".
    You can use F in a DEXRON application but not the other way around. TYPE "F" was also not available until 1968.
  9. Gotgas
    Gotgas
    from DFW USA
    Type F is for Fords
    It has a very slight "grit" to it, the Ford transmissions use this to get their clutches to grip better
    Old drag racers' trick is to use Type F in a GM trans to keep them from slipping..
  10. lincolnlog
    lincolnlog
    from Arizona
    thanks for the replies guys. I'll get to topping that off.
  11. Yeah, definitely always use the red stuff.
    Glad you found your dipstick.
