Projects It's T time for me...
Discussion in 'Traditional Hot Rods' started by thunderbirdesq, Jan 20, 2013.
  1. Dreddybear
    Dreddybear
    Fantastic. Can't wait to see more!
  2. mika112
    mika112
    great job .
    i like the frame work .
  3. Hapydz
    Hapydz
    Andy, a few questions for you...
    1. Are you going to set the floor down at the rear so you don't get a nose bleed sitting in it ?
    2. Is this your guitar quality build ?
    3. Will it be ready for the ba*****t next month ?
    4. You are coming one way or the other aren't you ?
    Ron
    p.s. looking great, man !!!
  4. thunderbirdesq
    thunderbirdesq
    Thanks guys!
    Hi Ron,
    1. The entire floor will be level at the bottom of the frame from the firewall to just behind the seatpan where it will connect to another panel that will separate the trunk from the cabin. The trans/torque tube will actually be IN the p***enger compartment and will be sealed off via boots similar to something found on a shifter... if that makes sense. Test fitting my lanky frame proved to be successful with a seating position similar to a lakes racer hunkered down behind the dash.
    2. Guitars are work, hot rods are fun! but, yes.
    3. No, I don't have the time nor the cash to make that happen.
    4. Yes, I'll be there! See ya soon!
  5. Slick Willy
    Slick Willy
    Sorry, Im late to the party!
    Looks great,Andy!
  6. swade41
    swade41
    from Buffalo,NY
    Oh, this is that thread..........where that guy is at it again, looking splendid !
  7. metal man
    metal man
    I think I've figured out how Andy builds these things so fast. He sneaks off and builds the car without anyone knowing it, and then AFTER it's finished he starts a build thread, posting update pics rapidly. Meanwhile, the finished car is sitting there waiting. He already finished this roadster, before he sold the coupe :D
    Seriously man, this thing is looking awesome. I like your style, and I'll see you in the ba*****t next month.
  8. the-rodster
    the-rodster
    That gage panel is way cool!
    Are you gunna run a temp sender in each head?
    Rich
  9. cakes
    cakes
    Awesome build. I look forward to seeing how you do the floors, as I am 6'3 and would love a t roadster one day
  10. h.i.
    h.i.
    from denver
    Awesome, watching this for sure. Loved seeing the 34 at bonneville, too. Hopefully have time to meet you this year. I'll be curious to see how many miles you can do before you cramp up, haha. Put a small gas tank in it so you can stop more often.
  11. h.i.
    h.i.
    from denver
  12. six pack to go
    six pack to go
    from new jersey
    Lookin great man, nice work as usual.
  13. h.i.
    h.i.
    from denver
    Are you using the stock mopar spindles/brakes or are you going to switch to ford stuff?
  14. thunderbirdesq
    thunderbirdesq
    thanks again boys, Metal Man, I WISH this thing was already secretly done, I'd have been doing snow donuts all week!
    Yea rodster, sender for each side.
    Hi I'm gonna bore out the axle and run ford stuff, easier to find and cheaper to rebuild. And then I don't have to get my tires remounted either. Right now the ford spindles are just sloppily mounted with the smaller diameter mopar kingpins.
  15. thunderbirdesq
    thunderbirdesq
    I borrowed my pal's 7* taper reamer and bottom-reamed the deuce spindles for a tie rod. Makes it a lot easier to push this thing around!
    I also cut all the toe board **** and front subrails out of the way to start making my cowl hoops to mount the steering box and brake pedal. I just centered and tacked the cowl to the frame to keep it in place for the moment. Also trimmed the lower firewall off, I'm going to make it kick out the whole way down like it does at the top.
    And I started mocking up the shocks, but decided I don't care for this arrangement... They will be cantilevered and mounted horizontally inside the frame and out of sight.
  16. Cantilevered shocks and a four bar?!? Andy's building a Boydster!
    The gold chains and pinky rings are next.:D:rolleyes:
    Love it Andy. Keep us posted on the progress.
  17. Donnj
    Donnj
    from North NJ
    any updates?
  18. thunderbirdesq
    thunderbirdesq
    53-56 F100 Gemmer box cowl steering setup tacked in place... I'll elaborate with better pics when it comes back apart for finish welding.
  19. thunderbirdesq
    thunderbirdesq
    Engine block checked out perfect! It's now bored .060 over, crank's reground, new cam bearings going in, guess my guy is having some trouble getting round cam bearings from a certain supplier... 3 different sets and all of them are a bit egg shaped, cam won't fit once their installed... We shall see how that plays out, he's waiting for a response now.
    Gonna go with a 1007b grind cam from Pete1...
  20. Window Licker
    Window Licker
    This thing must be about done by now
  21. chopo
    chopo
    its already been in 30 mags and prolly in denmark now.
  22. Window Licker
    Window Licker
    That sounds about right
  23. thunderbirdesq
    thunderbirdesq
    Ha! I wish... Progress has...... slowed.... to... a.. crawl. I wish I didn't have to make a living!
    I did manage to find a few spare minutes to knock 215 holes in the deck... Probably had more than a few T restorers rolling over in their graves. This was a NICE decklid! I also cut the inner structure out and replaced it with a thin x brace. Will need all the airflow I can get with the radiator back there. The lower panel will also get ventilated similarly.
    And I started knocking out a floorpan and installing it. Also whittled down a trashed, torched up set of '40 pedals and made it into a hanging brake ***y........ It will mount to a bracket on the front hoop behind the steering box with a '40 Ford MC on the firewall. Clutch pedal will be mounted RIGHT to the clutch crossshaft. No linkage! gettin there...
    It also steers! but my camera ****ped out before I got pics of that... coming soon.
  24. Rob Paul
    Rob Paul
    Sweet project. I gotta keep my eye on this thread. I like your pace!!
    Rob
  25. millersgarage
    millersgarage
    wait a minute.....radiator back there ??!?
  26. Looking so bad *** buddy! Can't wait to see it on the beach. Lets catch up soon.
  27. X2 - track nose with an itty-bitty opening???
  28. Mopar Jack
    Mopar Jack
    Looking good,as always Andy...
  29. OoltewahSpeedShop
    OoltewahSpeedShop
    The deck looks great, well... it all looks great.... :D
