Projects It's time for a new engine ! Oh well !
Discussion in 'The Hokey Ass Message Board' started by rob-redm, Feb 6, 2012.
  1. rob-redm
    rob-redm
    Well got the bad news today the engine in my 35 is a goner.
    :eek: What ever broke really made a mess of it. So going with a
    hot little 283 with a Duntov 30/30 cam and solid lifters most likely. I'm
    a little bummed that the engine is shot, but would have rather had it happen now then this summer. :D I will keep everyone posted.
  2. plymouth1952
    plymouth1952
    sorry man that ****s.
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    That ****s. I can relate. I have a 53 that needs an implant. and summers creeping up
  4. Hdonlybob
    Hdonlybob
    Yep, sympathies here too...
    But upgrading can be fun and rewarding too.
    Sounds like a good plan on the warmed up 283.
    Good luck,
    Cheers.......
  5. rob-redm
    rob-redm
    Hopefully back on the road really soon !
  6. curbspeed
    curbspeed
    What a heap! You should get your money back. Or s**** it out! Sorry to hear that pal. How about Olds powered? I bet Paul in Puyallup could get you going in the right direction.
  7. rob-redm
    rob-redm
    I don't think I want to mess with any of those old "Oldsmobile engines" they look and sound killer when done right... But going to stay as close to what was in it, Ole' Saphire would be happier that way... So no new wheels for this kid in the future... :D
  8. shoprat
    shoprat
    from Orange, CA
    It would probably run a lot better with the cam just smaller than the 30/30.
    They got no bottom end at all. Is the other just an F.I. cam. I can't remember.
  9. rob-redm
    rob-redm
    nothing set in stone yet to which way for sure , need to get a estimate on build.
  10. rob-redm
    rob-redm
    Ok, Having a 283 solid lifter engine built for 35, will get more info later... Soon to be on the road again..
  11. tjmercury
    tjmercury
    That ****s but gotta agree with you, better to happen now instead of in prime Cruz time!
  12. 32SEDAN
    32SEDAN
    Sorry to hear but your '35 is beautiful!
  13. need louvers ?
    need louvers ?
    Ooooffff, that ****s! I might be in the same boat here pretty quick. I have to run over to ElPolacko's shop and carefully peek under the intake on the Plymouth's 360 this weekend. Guess that holds the Real Rodder's wheels back a bit, huh?
    Oh, and I have to agree about the 30-30 cam. Nothing sounds as good, but for a car heavier than just a basic roadster, I'd call Comp cans and have them grind something to spec for your 283 in a solid lifter profile. Cams have come a loooong way in the last couple of decades. There is no reason to put up with huge holes in the powerband just to sound cool.
  14. revkev6
    revkev6
    from ma
    is there really any other reason :D
  15. Chris
    Chris
    What happened to the engine?
  16. BigChief
    BigChief
    Yeah, to not be a poser. There aren't many things more lame than a 'cool' sounding motor that can't back up the bark.
  17. treb11
    treb11
    post pics of the carnage or it didn't happen! sorry, just trying to make light of a bad situation. good luck with the build
  18. need louvers ?
    need louvers ?
    Ya, I'd much rather have an engine that has a nice usable RPM range, especially when it's coupled to something like an early Ford trans with some fairly steep gear ratio changes per shift in a reasonalbly heavy car. It's kinda called planning ahead...
  19. fab32
    fab32
    The 30/30 Duntov cam would be the worst possible choice for your car especially with only 283 ci. Cam technology has advanced eons since that cam was offered and it was a poor choice when it was new (the 350hp hydraulic would run circles around it even back then.
    Frank
  20. henry29
    henry29
    So what broke in the old 265?
  21. Graham M
    Graham M
    from Calgary AB
    Easily for you; 283's are fairly common.
    Otherwise sorry for the bad luck, but the timing wasn't too bad either!
  22. F-head
    F-head
    Rob,
    O'l saphire is so cool, you can do wrong with that machine
    B
  23. rob-redm
    rob-redm
    Here we go, don't what broke . But it put a rod out. :confused:
  24. rob-redm
    rob-redm
    It happened !
  25. rob-redm
    rob-redm
    Thanks Bruce, I hope to have O'l Saphire hitting the pavement again really
    soon.:D
  26. rob-redm
    rob-redm
    Couldn't find what went through the engine, unless it went out in the exhaust or is in the oil pan... dont quite know..whatever is was did it in for sure RIP 265 ci.. :confused:
  27. rob-redm
    rob-redm
    scored a polished set of Cal-Custom valve covers for my engine... things are coming along..
  28. Mr48chev
    Rob, I ran one of those 30-30 Cams in a 283. First in my T bucket and then the same engine went into my 48. You get damned sick and tired of adjusting the valves all the time if you plan on driving it a lot.
    The bark and lifter rattle may impress the mouth breathers but I'd go with a decent hydraulic cam and get more power and enjoy my Saturday mornings doing something rather than adjusting valves. Those engines really like something like the cams that came in mid 80's Z-28's.
  29. hotrd32
    hotrd32
    from WA
    Sorry to hear that man, just saw the thread. Sounds like your healing the wound fast. That would be my answer if my Chev V8 croaks. Actually I'm already planning for it. Trying to get ahead of the game. Course once I do it'll last forever...LOL!
  30. rob-redm
    rob-redm
    I won't be driving this one alot, maybe get a 1000 miles if that on between spring and summer. Billetoproof, Good***s, and a few local shows and open houses.. no more East vs West for this kid since I'm OHV guy... maybe Chris will let me drive my OT car in and I can park a few lots away.:D
