I've heard of engines being "boat anchors" before, but...
Discussion in 'The Hokey Ass Message Board' started by 26Tudor, Apr 24, 2011.
  1. I know the term "that engine is good for a boat anchor" but these guys took it seriously... wonder what kind they used to be?
  2. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    heres some more. 2 flathead fords.
  3. treb11
    treb11
    #3 is SB Ford, #2 I think is SBC
  4. greensheads
    greensheads
    the "complete" engine is a small block Ford.
    The first engine in the row is a 429/460.
  5. Larry T
    Larry T
    Second picture is big block Chevy.
    Third is small block Ford.
  6. resqd37Zep
    resqd37Zep
    from Nor Cal
    Runs good. Just needs a little cleaning.
  7. Normbc9
    Normbc9
    I'm a retired fireman and yes we had many of those. The Continental 866 ci inline six was the champion of all of them. Dual plugs, dual magneto's, three up draft Zenith Carburetors and a long time to start engine. It was a 12 volt (in 1956 that was just coming into the market place) and we even had the back wheels up on a ramp for a "Roll-off" start.Compared to the 935 and 1091 Hall Scott engines we had this thing was a costly problem. The power plant weighed 970 lbs too. It would have been a great anchor!
  8. Mr48chev
    Pretty common when junk iron was cheaper than concrete and a sbc bare block weighs right at 150 lbs and some of the big blocks go over 300.
    When those were dropped in the water you could probably get clean cracked blocks at the local machine shop for hauling them off so they didn't have to. Now days it's a wonder that a scrapper doesn't haul them off at low tide in the middle of the night.
  9. redlinetoys
    redlinetoys
    from Midwest
    So what is the story behind these?
  10. There are those, and literally dozens more, maybe up to 100 of them, sitting in the harbor in Trinidad, CA, about 15 miles North of Eureka. I was down doing some shopping last weekend, stopped by my favorite beachfront seafood joint, and there they were... that's all I know.
  11. chaddilac
    chaddilac
    That'll hone out... maybe .010 at worse case! :D
  12. #3 is a SBF but looks like a 351W judging by it's width
  13. GaryB
    GaryB
    from Reno,nv
    whats this I keep hearin about molasass
  14. Good on bread...
  15. Vendome
    Vendome
    I see one still has pan gasket material stuck to it. Now that's some good gasket cement!
  16. Brad54
    Brad54
    from Atl Ga
    Little electrolysis bath, and those will clean right up.
    -Brad
  17. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    The wide 351 is the M. I know because I'm the unlucky sap who has one in their vehicle. C and W motors were the narrow (small block) ones
    Around home people used motor blocks as anchors for their floating duck blinds.
  18. Just needs a little TLC.;)
  19. Sheep Dip
    Sheep Dip
    from Central Ca
    "Ran when parked"!
  20. ironandsteele
    ironandsteele
    Ha. Beat me to it. :D
  21. FACT! A 351W is wider than a 302. Hence why I say that it's a 351W. It's not a Cleveland or an M due to the wet intake ( in this case a VERY wet intake):D Now it's just semantics and I'm being pedantic while being didactic!;) and now to be pragmatic it's just a rusty boat anchor!:rolleyes:
  22. firingorder1
    firingorder1
    More like ran when sank.
  23. ironandsteele
    ironandsteele
    Huh? The W was for Windsor.
    No?
  24. Those in the first pic are pontiac & olds. The second is a small block chevy 400 it has 3 core plugs. The third is a 351 winsor ford. Anyhow that it my guess OldWolf
  25. Larry T
    Larry T
    You can tell the second one is a big block by the main caps, small blocks use all "squared off" caps like the front cap in the picture.
    The third is 351 Windsor. The rocker arms are in line (wedge) so it's not Cleveland or Modified (canted valve, like BBC or 429/460 Ford). The intake is wider than a 221-302 so it's 351.
    Larry T
  26. losthubcap
    losthubcap
    from Upstate NY
    The one on the end of the chain appears to be a Barnacle Block !
  27. Ran when parked. :rolleyes:
    Have you ever considered that statement. Unless it was scattered it most likely did run when parked or at least ran until it was parked.
  28. captainjunk#2
    captainjunk#2
    hmm seasoned blocks ready for magnafluxing ,
  29. wildearp
    wildearp
    from tucson, az
    "running when pulled"
  30. dudley32
    dudley32
    I need those chains...can they be Plated...?? :rolleyes:
