Technical J&S t5 adapter
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Jan 16, 2015.
  1. wheeltramp brian
    wheeltramp brian
    looking for info ....just got a j&s t5 adapter for behind a gm bellhousing from a customer.he bought it from another guy.looked em up online and found their website but they dont mention anything about selling these. its cast J&S on the bottom .any info would be great thanks
  2. jseery
    jseery
    from Wichita KS
    Not sure what your referring to here, is it the plate type of adapter?
  3. S10 T5s have a longer input shaft and I have heard of people putting a plate between the transmission and bell housing to make up this difference. Also, the later S10 T5s have a Ford bolt pattern. It is possible someone has made a plate adapter for mating this transmission to the Chevy belhousings. Why don't you post a couple of pictures?
  4. gimpyshotrods
    gimpyshotrods
    These are easy enough to get, from a variety of suppliers.
  5. Mr48chev
    Most likely it is something similar to this one on Ebay 191474011114 Cast plate machined to space the trans off the bellhousing the correct distance and made to locate the trans correctly.
    This one is a bit more elaborate
    191474010056
    There was also one that looked more like it was cut out of a piece of steel plate with a waterjet or plasma that I didn't put the link to.
  6. wheeltramp brian
    wheeltramp brian
    bttt .yes this is a spacer plate .i just put one behind a 235 in a 54 chev at work and it worked out great.im thinking of puting the t5 behind my 57 pontiac engine in place of my 53 ford 3 speed with o/d in my 29 .wondering also what power a stock s10 unit will take. thanks
  7. kennyg1931
    kennyg1931
    I bought one off a guy here on the HAMB . the name was Hot Rod Works and am very happy with it . His number is 208-455-7971 He should be able to answer any questions you have !
  8. kennyg1931
    kennyg1931
    His web sight is Hot Rod Works . Com :
  9. 38Chevy454
    38Chevy454
  10. bjinx
    bjinx
    There is a guy on here that makes T-5 adapter plates. His user name is INLINE and he has a web site called Vintage Metal Works. Got an adapter to put a Mustang WC T-5 on my SBC. Nice guy, had my adapter in 10 days, reasonable price, 10% off for Hambers.
