Technical Jack under differential
Discussion in 'The Hokey Ass Message Board' started by blowby, Jun 4, 2015.
  1. The37Kid
    The37Kid
    A worn out wool body polishing pad on your floor jack pad should protect the pumpkin. Bob
  2. clem
    clem
    I don't think your wedding cake is capable of worrying about things.......Definately different ways of speaking/writing, compared to the English that we use. I accept that......
  3. stimpy
    stimpy
    must have had a senile moment with the not , or it could be a NOT, not joke ..:p:D
  4. stimpy
    stimpy
    so your not the Cambells pork and ****** ????
    as for the friends who drive Fords , if they drive a Ford to begin with they are not my friend . ( specially after they ask me to fix the Forked Over re*****d design parts changing every quarter or 3 full moon Vehicle .. never had a Gm where you had to know the plant , Day and shift your car was built to and the color of the car too sometimes , just to order parts for it . . and the late 70's early 80s 302s and 351s with their metric fasteners on one side Imperial on the other ( someone in engineering had a sick sense of humor )
  5. 5window
    5window
    Me,too.
  6. oj
    oj
    Is that the rear ford put a plastic cover on? Where the tooth of the puck on top of the jack can punch a hole in the cover when lifting?
  7. gimpyshotrods
    gimpyshotrods
    Only if you don't watch what you are doing.
    There are several million on the road, and this never proved to be an issue.
    I took my 8.8 cover to the rifle range. it's stronger than you think.
  8. Blue One
    Blue One
    from Alberta
    Again, what about jacking up a car with a quick change rear end ?
  9. Blu
    Blue, you'll have to buy 4 "Back to the Future" Hover Boards™ and park on them! No more magic ramps like in your avitar! :D
    I've seen the warning in Ford manuals also, but both my cars have the IRS 8.8, so I thought it was just for them. Seems like their was a note about bearing damage, I ***umed they meant the inner CV's on the axles because the center section is rubber mounted, but who knows?
  10. Really? you'd be concerned about a 9"?!.
  11. Blue One
    Blue One
    from Alberta
    :D Those magic ramps have been awful handy when crawling around under the car.
    If I was a little better off I'd have a 12' ceiling and a magic 4 post car hoist.
    The older I get the more I'm leaning in that direction. :D
  12. Yup, know the feeling! I puled the Plymouth onto a set the other day to check something under it, and my fat @ss still wouldn't fit! Afterwards I realized I should have backed it on so the rake wouldn't work against me! I have a Quick Lift in the shop (not enough ceiling height for a full lift), but I tore the T apart on it.
