Jacked up model A
Discussion in 'The Hokey Ass Message Board' started by Durty Mick, Jul 21, 2005.
  1. Durty Mick
    Durty Mick
    Ok, I posted this in the wrong place first, think I got it now....(sorry im new)I have a '29 model A pickup that has been giving me problems for a few months now. I start it cruise around the block and it starts getting hot quick! Water shootin' out of the top of the radiator and everywhere else it can fit! My temp gauge wasnt workin, so put in a new one and it goes from 130 deg ta 240 in about 5 minutes if car is idle, less if driving! I took the radiator in, got it pressure tested, they fixed that, than I got new water pump.....so I don't think it's either one of those! (Unless the core of radiator) Someone recommended my head gasket.....So, sure enough pulled the head off but the gasket looked alright to me....I decided to do some further inspecting so I pulled off the valve stem cover on the side and the oil seemed really black and thick to me....(Just changed it not too long ago) and it was also gritty. One more thing..the spark plugs were pretty black too....Is it time to rebuild? What is causing the grit? Do you think the block is screwed? I would appreciate some help guys.......
    Durty Mick
  2. guiseart
    guiseart
    Did you mention what kind of engine?
    Did you post in Introduction?
    Did you do a search on overheating problems to read the other threads about this problem?
  3. daddyo54
    daddyo54
    from Denison Tx
    Sounds like a stuck thermostat.Sometimes it'sthe simply stuff we overlook.
