Technical Jacking Up Flathead V8 - Water Pumps
Discussion in 'The Hokey Ass Message Board' started by Mark Shaw, Jan 13, 2018.
  1. Mark Shaw
    Mark Shaw
    I'm replacing the water pumps and front motor mounts on a flathead V8 in my 1949 Ford. The manual just says to jack up the engine, but does not explain where it is best to do this. I did this way back in the 1960s when I was a teenager on a 1949 Ford sitting in somebody's back yard. Don't remember how I managed it back then.... :-(
    Is it safe to use a floor jack with a 2x6 wooden plank under the oil pan? Not sure if the load will distort the oil pan.
    Thanks for any help or other suggestions.
  2. s55mercury66
    s55mercury66
    from SW Wyoming
    Maybe use an engine lift and pick the engine up that way? Personally, I think a board under the pan will work fine, but can't say it will. You could also look and see if there is any place down there to jack it up from, maybe fab up a cradle to use with a jack.
  3. Mark Shaw
    Mark Shaw
    The front of the engine is over the suspension cross member ad not easy jacking point s can be found.
    A "cherry picker" from the top is possible (I have one), but then access to the underside to the pumps and mounts is really cramped. I have the luxury to have a 4-post lift in my garage.
    Which brings me back to how did I actually complete this task back in the 1960s without either a cherry picker or a 4-post lift?
    Maybe being young and naive back then is the way to go?....:)
    s55mercury66 and spurgeonforge like this.
  4. RidgeRunner
    RidgeRunner
    from Western MA
    I've used a board and jack at different times with different engines with no damage, maybe I've just been lucky.
    Young, naive, and more limber back then in my case.
    Ed
  5. V8 Bob
    V8 Bob
    I replaced the pumps on my '51 by carefully jacking under the oil pan, using thick/dense padding on a board to minimize any pan distortion.
  6. Petejoe
    Petejoe
    from Zoar, Ohio
    Yes. Use it close to the two front corners of the pan. I’ve done this many times.
