Jag IRS Geometry?
Discussion in 'The Hokey Ass Message Board' started by Bungi, Feb 17, 2011.
  1. Bungi
    Bungi
    Guys -
    I'm working on a project car and want to duplicate the design/geometry of the classic Jaguar rear axle with the single lower control arm and dual coil-overs. Anyone out there have a detailed drawing, rear view of the axle? I'm interested in the relationship between the universals and the location of the control arm pivot points.
    Thanks
    Rick
  2. 53sled
    53sled
    from KCMO
    there are two threads going recently about using the stock cage or not. might help you find what you need.
  3. Slag Kustom
    Slag Kustom
    pinion is off set to passenger side about 2 inches
  4. Warpspeed
    Warpspeed
    Quick answer is driveshafts both dead straight and horizontal.
    Lower arms slope up about 65mm to the diff.
    Set pinion dead horizontal, pinion centre is displaced 50mm towards the right.
  5. Pir8Darryl
    Pir8Darryl
    A simple search will not only answer all of your questions, but also provide you with mountains of additional information. Search for IRON MAIDEN's recent thread. He has been gathering tons of the technical information and specs that a lot of the other Jag IFS/IRS swappers leave out.
  6. Hnstray
    Hnstray
    from Quincy, IL
    In addition to the above recommendations, a Wikipedia search of Jag IRS will produce some excellent photos and other info related to the Jag rear suspension.
    Ray
