Technical Jaguar suspension for 1950s Chevy Suburban???
Discussion in 'Traditional Hot Rods' started by oldschoolantiqueauto, Jun 26, 2021.
  1. I am looking at a 50 Chevy suburban project truck. The original suspension is gone. It's sitting on blocks. But the seller has the front & rear suspension out of a 1984 Jaguar sitting a-side for the suburban. Part of his asking price is based on that Jag suspension.
    I know nothing about Jag suspension? Can any one tell me if a 84 Jag suspension would be good under that truck? Or is it junk to use???
  2. Tim
    Tim
    from KCMO
    I know @***us has put them under Ford F trucks before and that’s about where my knowledge ends.
  3. Lloyd's paint & glass
    Me neither, other than its not hamb approved.
  4. mgtstumpy
    mgtstumpy
    S1 68-73
    S2 73-79
    S3 79-92
    Very common conversion down here however not HAMB friendly. When you add front end, rubber bush it and use appropriate uni joint on steering
    Tim and VANDENPLAS like this.
  5. Had the front clip under my 50 fleetline and worked great.
    As long as the width is correct it should work.
    Jaguar is a heavy car so weight should be close to your ‘burb
    Parts are not very expensive to rebuild the suspension and brakes
    rear rotors are a pain right on the inside of your pee hole to replace and so are the parking brake slippers
    so do them now while they are out of the truck
    Good luck
    fauj and jimmy six like this.
  6. I see what you all are saying, "not HAMB approved" I don't want to use it at all. I have a complete running 57 Chevy ch***is I 'm planning on sitting the panel truck body on. It's a 52 clam shell Suburban, complete with all the interior & it's a clam shell back door. That alone is very much in demand. But 6 grand is a bit much for it's condition. I would be wanting to sell
    the Jag suspension to try to make the panels price closer to the value I put on the truck.
    Is there a value in the suspension.
  7. Guy Patterson
    Guy Patterson
    Yes there is just not here on the hamb
  8. Hnstray
    Hnstray
    from Quincy, IL
    A couple of observations/opinions. If you don’t want to use the Jag parts, any reason will do. But if your “57 Chevy running ch***is” is a p***enger car unit, it is really unsuitable for the truck body. You would be better off in work required and final outcome using the original truck ch***is with Jag suspension units. Or alternatively the stock ch***is rails with ‘other choices’ for suspension upgrades, including reworking the stock leaf springs, shocks, etc, possibly a dropped axle.
    As far as being ‘not HAMB friendly’, there is no shortage of naysayers on this forum. I disagree with that opinion and a search of HAMB archives will turn up several threads and lots of posts from a few years ago when this topic was widely discussed.
    The less desirable inboard rear disc brakes can be easily replaced with later axle/brake ***emblies that use outboard disc. As for value of the Jag suspension ***emblies, I think they could vary between a couple hundred to several hundred, depending on condition, completeness, axle ratio, etc. To be clear, I AM NOT trying to persuade you to use the Jag stuff, only pointing out there is more to the decision than whether or not it is ‘HAMB’ friendly…..unless you choose to believe that after investigating prior threads and it is the main determining factor in your decision.
    Ray
    XXL__, fauj and osut362 like this.
  9. OK thanks, I understand. I hate to p***-up the truck. The Suburbans have gotten so popular that a-lot of the hard to find parts, are now being re-popped, like the seats. But this one is already complete. Just no running gear. It also comes with a L24 motor & trans sitting aside. I no nothing of these motors. He clams it's in the LS family? None of the running gear means anything to me except to recover some of the price of the body...
  10. Hnstray
    Hnstray
    from Quincy, IL
    @oldschoolantiqueauto
    There is another option to consider. Several hot rod parts vendors are offering new ch***is for popular Ford and Chevy trucks with running gear (aka ‘rollers’) designed and built to just bolt on your body. Expect to spend $10,000, give or take some, depending on options. It dramatically reduces build time and provides a solid foundation. Depending on your skill set and equipment, that $ figure may be more attractive than you might initially think. It costs you nothing to research what’s available.
    Ray
  11. 38Chevy454
    38Chevy454
    Have full Jaguar IFS and IRS on my 52 GMC pickup. Same basic frame as your Suburban. See avatar pic. Much preferable to a frame swap since you keep the original frame. PM me for details if you want more info.
    VANDENPLAS and 5window like this.
  12. Thanks Ray, Yea I already have a real big project," my 39 COE " taking most of my time & cash. I would want to just put it back to semi stock aria suspension just to get it to the next level. Get it drive-able, new gl***, seat covers & cleaned up to present for the next guy to build.
