Jahn's Cast Piston Clearance
Discussion in 'The Hokey Ass Message Board' started by rhpope, Oct 21, 2009.
  1. rhpope
    rhpope
    Does anyone know what the clearance is supposed to be on these? They are FE 406 pistons, 0.030" over (4.19" bore)
    It seems that I remember reading somewhere that it could be as high as 0.005"-0.008" clearance for the cast pistons because they were such heavy and thick castings since steel re-enforcements were not used like most other cast pistons.
    Thanks,
    Roger
  2. gary terhaar
    gary terhaar
    from oakdale ny
    When i get a piston with no info on it at all ,i measure it then sit it on a hot plate untill about 200 deg and remesure adding in a thou or two for oil.
  3. rhpope
    rhpope
    Gary,
    That is a good idea, I have never thought of that.
    However, don't most pistons run at a temp of around 500-600° F? If, 500-600° F is the operating range, then would that not be better to measure them at. You could do this in a regular oven since you can easily get an oven to go up to 500° F.
    Thanks,
    Roger
  4. gary terhaar
    gary terhaar
    from oakdale ny
    Over 300 the heat trating if any is lost,the piston will be like penut****er. piston running temps are well below that. combustion chamber temps are another story .
    If you look at the bottom of a used piston the oil is baked a golden brown(med heat) if it was at 500 you will see black chared oil
