Projects Jamb switches
Discussion in 'The Hokey Ass Message Board' started by skinny pedal, May 2, 2018.
  1. upspirate
    upspirate
    Wait til you get the harness if you can.Most come with dome light circuits I believe and follow their instructions.Dome light switches can be bought at any auto parts stores, see what will work. May have to reuse the bracket shown. I like the under dash lights that come on with the open doors, and wire a separate switch to light the dome separately
  2. skinny pedal
    skinny pedal
    Well those are cool, I don’t want them hanging out. Wonder if I can set those back into the jam somehow.. ?
    I like the way you think. I’d better leave well enough alone until I get the new kit in. Until then it’s a good ol fashion toggle to get the dome light on.
  3. Atwater Mike
    Atwater Mike
    My '55 F100's a Custom Cab, came with door switches both sides. (best switches to use are the Ford style, as was shown previously)
    I wired a shunt from my driver's door switch to a hidden toggle under the fender which goes to my horn relay...Toggle off and it's normal, inside cab light plus a courtesy light under dash;
    Switch the toggle on and my 'alarm' is set. Relay goes to my '72 Cad Eldo horns, with a '76 Olds 'tweeter'. Sounds like the Atchison-Topeka-and the Sante Fe when it goes off... Nice voice for an F100.
  4. upspirate
    upspirate
    Also, leave the current wire in place, maybe it can be used to "fish" the new one through the pillar up to the light
  5. skinny pedal
    skinny pedal
    Lol that’s a great idea I’d like to do that too.
  6. Engine man
    Engine man
    from Wisconsin
    The one with the screws on it is the switch. The other is the magnet. You could use a stronger magnet inside the door and mount the switch on the inside of the door frame with no holes at all, as long as you have a strong enough magnet. There are round switches but most of those are closed when the magnet is near them.
  7. squirrel
    is this an old truck, or a street rod? :)
  8. skinny pedal
    skinny pedal
    There are lots of options, so at least I’m not stuck without any. I appreciate all the ideas and I’ll post something when I decide what the best one for my situation will be. Thanks everyone.
  9. olscrounger
    olscrounger
    No need to replace the stock one wire dome light if the wire is good. feed it with a relay closed by the door jamb switch via ground. Do it all the time on 40 fords with one wire dome lights. As someone mentioned it is nice to also have under dash lights. Illuminates the floor area nicely. The ones out of a late 70's early 8o's cutl*** and Buicks work great. My wife likes the underdash light as it allows you to see in front of the seat on the floor in a 40 coupe.
    lothiandon1940 likes this.
  10. skinny pedal
    skinny pedal
    Well squirrel, it’s a 55 Chevy, you’ve helped me on this project about a year ago when I’d just gotten it.
  11. squirrel
    I know, it was a rhetorical question, for the guys suggesting you use the latest street rod parts in your old truck
  12. skinny pedal
    skinny pedal
    Oooh, I got ya squirrel, I’m a little slow sometimes...
  13. skinny pedal
    skinny pedal
    One quick one squirrel, will a 57-59 turn signal ***embly work on my 55 since I’ll be putting in a new American autowire kit in this winter? I just mean will it physically fit on the column behind the steering wheel. It still has the stock skinny column in it. I know that’s a pretty specific question, but something tells me you will know! Thanks sir.
  14. squirrel
    It's a good question. The switch was modified slightly when they went to the deep wheel. The lever is angled forward, and the hole in the housing is larger to allow for it. The casting inside that the lever screws into is different.
  15. 325w
    325w
    The 1954 Chevy car turn signal switch will work on the 55 truck.
  16. squirrel
    the 53-54 car switch is the same as the 54-56 truck switch. The 57-59 truck switch is a bit different. They're all kind of hard to find in good used condition, but repops are available. I don't know how well they are made.
  17. skinny pedal
    skinny pedal
    Ahhh... good deal, thank you :)
