Technical Jamco pcv kit for 8BA
Discussion in 'The Hokey Ass Message Board' started by robracer1, Sep 28, 2018.
  1. robracer1
    robracer1
    After installing the pcv kit on my 1950 ford I lost the use of my vacuum wipers, my question I understand that a vacuum storage canister with a check valve will restore the use of the wipers, so is there someone that is doing this, if so which canister are you using and how is it working.
    I know the best way to do this is to install a 12v wiper motor and if I was going to keep this car I would.
  2. I didn't know there was kit for the 8BA. I might look into that.
    I’m sure you could find another vacuum source for the wipers - maybe a carb spacer with a port?
  3. Jack E/NJ
    Jack E/NJ
    from NJ
    You don't need a PCV kit. All you need is a Chrysler style oil filler cap on your fuel pump stand with a 3/4" hose barb and a 3/4" hose to the air filter can. That'll take care of the crankcase fumes you're getting inside the car. Jack E/NJ
    brsturges likes this.
  4. robracer1
    robracer1
    I know someone has used a vacuum tank for wipers, just need to know what was used.
  5. Mr48chev
