Technical ***January 2017 Banger Meet - Happy New Banger Year***
Discussion in 'Traditional Hot Rods' started by Jiminy, Dec 31, 2016.
  1. modelAsteve
    modelAsteve
    "tractor" pp does NOT have counter weights
  2. I believe he is referring to the 42-47 1/2 ton PU rear end. It's a banjo type rear end but open driveline
  3. Will have to ask/ make sure, as they are with and without.
    By searching on ebay, I found, that the used ones, out of a Ford 2N/8N/9N tractor, is usually pictured with the counter weights.
    Most of the new replacement is not.
    ... not that that makes it deffinitive!
    Keep 'em kruzin!
    Dannerr
  4. "I believe he is referring to the 42-47 1/2 ton PU rear end. It's a banjo type rear end but open driveline"
    Plus parallel leaf suspension.
  5. Yeah, there right over there next to the bin full of hen's teeth
    Andrew Mccann and Dannerr like this.
  6. Dustyp489
    Dustyp489
    Any of you F.A.S.T. menber ? Wanted to know if you got the 4-2016 Mag./news letter. My copies this year have been running late all year.
  7. waxhead
    waxhead
    from West Oz
    My 4-2016 FAST magazine arrived in Western Australia today.
  8. V4F
    V4F
    from middle ca.
    got mine FAST like yesterday ...............
    I believe this is what Bluto was referring to .
  9. Bearing Burner
    Bearing Burner
    from W. MA
    I haven't seen my FAST copy yet.
  10. Midnight Rider
    Midnight Rider
    from Australia
    28 coupe at home 3.jpg 28 coupe at home 2.jpg 28 coupe at home.jpg 28 coupe engine 2.jpg
    Happy Australia Day.
    This car just hit our town and fronting up to local runs.
    Enjoy the pics. Will get more info soon.
  11. waxhead
    waxhead
    from West Oz
  12. V4F
    V4F
    from middle ca.
  13. Wow, That is a Sharp looking ride, Very Nice.
    Are those AC lines I see on the right side? I almost said passenger side, even though left hand drive.
    John
  14. V4F
    V4F
    from middle ca.
    is anyone running a quick change on the street ? just got mine together (derek/judy) and it has a wurring sound . not a ring & pinion noise . I figure it is just more gears turning . help appreciated ............ steve
    * small model a center .
  15. Steve I've never run one but always heard about the quickchange whine. I think its just part of the charm
  16. Some are more noisy than others. Depends on the clearance, backlash and gear tooth angles on the spur gears. Mine has one rpm range where it really sings. Whirring would be nice!
  17. V4F
    V4F
    from middle ca.
    I kinda figured that as it is not a ring/pinion typical noise ......... thanks
    mine is tight as all is new . brg/races etc
  18. PhredH
    PhredH
    I put a Kiwi QC in last spring, love it. So will you.
    Like Tiny said: "it's part of the charm", due to the straight cut spur gears.
    Have fun!
  19. V4F
    V4F
    from middle ca.
    thanks . mine is from derek also . just making sure as its not cheap ........
  20. Midnight Rider
    Midnight Rider
    from Australia
    Yes John, A/C, Tilt column, cruise control , Column shift Torqueflite auto, 8 inch diff, twin 81's, full pressure, 4 bar front and rear, disc/drum brakes, coilovers. A wild mix of trends, but boy oh boy what a nice ride, and a beautiful motor set up. Was guy out of Visalia who built it and he deserves the credit.
    Outback likes this.
  21. waxhead
    waxhead
    from West Oz
    What sort of OHV set-up is it. Cant quite make it out. Riley 2 Port??
  22. jim1932
    jim1932
    1. Ford A and B speed
    hey, got my head back from being cleaned up. The top is primed,. It will sit for a month or two in my house. Is there anything I need to put on the combustion side (light coat of oil?) to protect it?
  23. V4F
    V4F
    from middle ca.
    a light coat of oil will protect the chambers & surface from rust
  24. jim1932
    jim1932
    was probably a stupid question... was more wondering if there was something other than oil. Probably not since it didn't rust the 6 month in my basement before they were cleaned up.
  25. Bullington
    Bullington
    1. Northwest HAMBers
    Looking to add a Stewart Warner tachometer to my 1931 Model A banger, does anyone have some ideas or part numbers? Looked around and there are a metric shit ton of options.
  26. [QUOTE="jim1932, post: 11886797, member: 139134" was more wondering if there was something other than oil.[/QUOTE]
    Try some Gibbs
  27. hardtimesainit
    hardtimesainit
    That would be a TWO port, at the intake is on the right side. FOUR port, the intake ports are on the left (driver) side.
    I have 4 port pictures of head showing ports with altogether different intake.
  28. hardtimesainit
    hardtimesainit
    WD 40 !
  29. hardtimesainit
    hardtimesainit
    Yes, I have had mine (Kiwi) model A type, on the street for several years now. Quiet as a mouse...too quiet !
  30. jim1932
    jim1932
    Yes I know the Carb is backwards in the photo...... What would be the operating effect of adding a spacer between the carb and the intake to make more room for headers. Headers would be wrapped to reduce heat transfer. Thinking one to two inches.
    Dannerr likes this.
