Technical ***January 2022 Banger Meet Thread - Bring it on 2022***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jan 1, 2022.
  1. Jiminy
    Jiminy
    Link to previous month: December 2021
    Coming Events: (PM Jiminy with additions/corrections)
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there maybe more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    chryslerfan55 and Crazydaddyo like this.
  2. denis4x4
    denis4x4
    from Colorado
    Happy New Year...checking in
    winduptoy likes this.
  3. Dustyp489
    Dustyp489
    Happy new year to all , hope this year is better.
  4. Happy New Year!!
    J
  5. noboD
    noboD
    Here, hope this year is better then last.
    The37Kid and winduptoy like this.
  6. Russ B
    Russ B
    Happy new year. My 2022 banger goal is to get my Terry Burtz block and get it together.
  7. Stovebolt
    Stovebolt
    Happy New Year to all you banger guys - Hope all your banger plans work out.
    Recently the jets in the strombie 97 on my winfield headed B motor in my coupe went from 45's to 43's. The motor is a little down, 0.040" up with a small score in #2 bore. Anyhow is leaves a nice black exhaust residue on the rear bumper. The valve lash has been corrected.
    A friend suggested I run hotter plugs to try to burn any residual oil and hopefully minimise the amount of exhaust residue. I run a stock B dizzy, and NGK AB-6 plugs. The next hotter plug available out here are NGK AB-2, which is a big jump.
    I bought some 14mm adapters for it.
    So my question is - does anyone have first hand experience as to what plug I should run in these adapters - the parts suppliers have no plug details on their websites, given I want tot try a slightly hotter plug than the NGK AB-6's
    Thanks in advance to all you guys - you're all a wealth on knowledge and these banger threads make for compulsory reading each time I log onto the HAMB.
    Old Dawg and chryslerfan55 like this.
  8. guitarguy
    guitarguy
    I wonder if this will be the year I can get the Fronty fired up.............
    Jet96 and winduptoy like this.
  9. guitarguy
    guitarguy
    If you bought 14mm plug adapters, the world is wide open. the next hotter plug is a NGK with a 5 in the heat range. I guess the next question is how deep are those adapter to get the right plug reach? My guess is 3/4", So maybe something like BR5ES.
  10. Phil Damon
    Phil Damon
    from San Diego
    Happy New Year! Got the new motor installed and running this last week.
  11. G_Don
    G_Don
    So the oil filler tube wasn't tightened at the bottom, thats why it was leaking a lot... Now it just leaks a good amount, but I'd like it to be less... But, run em, wreck em, never check em so I've been driving it.
    Also, got new shoes on it as well... super bright yellow kelseys that I thought I got too bright at first, but now I'm kinda diggin the look. Might be a little too low in the front cause I get the tires to rub on a tight turn, unlike on the chrome reverse wheels I had on it.
    Anyway Happy New Years banger dudes!
    Gordy
  12. guitarguy
    guitarguy
    Looks good. Tire rub could be a different offset on the wheel or tire size variation. I like it though with the wires. The color can vary alot on screen. It is bright for sure, but my blue wheels seem to stick out alot too. It's just a clash of two wildly different colors.
    pivir123, v8flat44, Old Dawg and 9 others like this.
  13. general gow
    general gow
    MODERATOR
    Jet96, winduptoy and chryslerfan55 like this.
  14. Kevin Pharis
    Kevin Pharis
    from Califunny
    This years plan is to pull the motor out of the speedster... and install the Akron-Hed with dual Winfield’s!!!:D:D:D
    8457FF85-19D4-42AF-B6CC-8C03DD9C058E.jpeg ADD599F5-DB1B-4367-BE8C-D430E42EFFDD.jpeg
  15. G_Don
    G_Don
    The wires rub quite a bit in the front. I think theyre equivalent to a 550 bias ply (but Im running radials). I have a 4" drop axle and reverse eye posies spring up front. Also don't have front shocks yet. I need a torch to bend up some f1 shock brackets.
    I love your T roadster! I really wanna build a 23-25 full fendered roadster in the future.
    Gordy
  16. Stovebolt
    Stovebolt
    Turns out the spark plug adapters I bought (commonly listed on part supplier's websites) are 22mm, and the Winfield head has 18mm plugs ..... oh well, back to the drawing board.
  17. Double check, I have one here with 16mm plugs
  18. Binger
    Binger
    from wyoming
    Checking in from Wyoming!
    G Baese, Jet96 and winduptoy like this.
  19. guitarguy
    guitarguy
    When you figure out if you have 18mm or 16mm threads (you can get 18mm to 14mm adapters online), then you can go to here and search a plug :
    https://www.ngk.com/search/reverseengineer?ptid=8&specs=165325
  20. Kevin Pharis
    Kevin Pharis
    from Califunny
    I know international shipping charges are hard to justify at times... it would be real easy to make those 22mm threads into 18mm.
    Stovebolt likes this.
  21. s.e.charles
    s.e.charles
    somebody will most likely scold me, but my search-foo must be turned off because i couldn't find the 'blown banger' thread . . .
    but could anyone share some information on this car, and specifically the blower set-up?
    the video was supposed to start @ 1: 43 minutes!
    thanks
    Old Dawg likes this.
  22. Fabber McGee
    Fabber McGee
  23. s.e.charles
    s.e.charles
    no; but that's a good reference, too.
    the car in question says "we do it" on the side but that's all i can make out.
    if i were more technical savvy, i could post a screen shot.
    oops; i guess i am!
    winduptoy and Old Dawg like this.
  24. V4F
    V4F
    from middle ca.
    my car is on jack stands again ................ steve
  25. winduptoy
    winduptoy
    Happy New Year all you banger nuts
    gone until March so nothing happening until then
    anyone in the Joshua Tree/Indio/Yuma area
    Jet96 likes this.
  26. Stovebolt
    Stovebolt
  27. That Supercharged dirt car used to be mine. The white twin cammed hill climber at 2:08 was mine also. There is information on both cars on my web site. C***_Casmir (buymegivemetakeme.com) Just select the links to "The late 1920's Fronty Ford" and the link to "1927 Gemsa T powered hill climb car"
    Dustyp489, s.e.charles and rwrj like this.
  28. 282doorUK, rwrj, Dustyp489 and 2 others like this.
  29. Tribalmonkey
    Tribalmonkey
    Happy New Year!
