Technical jb weld cure time
Discussion in 'The Hokey Ass Message Board' started by topher5150, Mar 21, 2022.
  1. topher5150
    topher5150
    I used some jb weld to fill in some cracks in my steering wheel about 24 hours ago. The thinner spots feel pretty dry but the thicker stuff is still kind of sticky. I this going to take a couple days to fully cure?
    lothiandon1940 likes this.
  2. big duece
    big duece
    from kansas
    Usually its rock hard in 24 hrs, if it's mixed with even ratio. It it cold where your at?
  3. topher5150
    topher5150
    40s-60s right now but i'm doing this indoors.
  4. lothiandon1940
    lothiandon1940
    Did you clean the wheel good before applying the JB Weld? Steering wheels absorb a lot of oils over the years. I'm thinking it could compromise the stuff and make it not cure properly.
    da34guy and big duece like this.
  5. 1pickup
    1pickup
    I tried that trick on a '63 BelAir wheel. It cracked again pretty soon after it was painted. I'd try something besides JB next time.
  6. topher5150
    topher5150
    I wiped it down before I started. It doesn't smudge or anything just feels a little tacky in some spots. I didn't want to go ham on it with a sander and make a mess of everything.
  7. dan c
    dan c
    i did one in the '70s and used epoxy (?) and epoxy paint. worked like a charm!
  8. rusty valley
    rusty valley
    PC 7 is what lots of folks use to fix steering wheels. Its more flexible.
  9. gene-koning
    gene-koning
    I'd say if its been sitting 24 hours and hasn't set up, it was probably not mixed properly, or mixed fully, at least that was when I had problems with it.
    I did mix some once when the temp of the material I put the JB weld on was cold and damp ( the material was near 32 degrees), it didn't set up worth a ****.
    If it hasn't set up by tomorrow morning, I'd chip it off, warm up the material and try again.
  10. ronzmtrwrx
    ronzmtrwrx
    Second on the PC-7. I used it to fix a 36 wheel.
  11. Marine tex works well.
    Al.
  12. SPEC
    SPEC
  13. gatz
    gatz
    4th on the PC-7
    Worked out great for reducing an 18" OD steering wheel to 16"
  14. goldmountain
    goldmountain
    I did the cracks in my steering wheel with Bondic. It is a clear plastic material that is applied with a small eyedropper. The nice thing about it is that you don't have to worry about mixing the right ratios of filler and catalyst. It sets up when you shine a small LED light on it that is supplied with it. Seems to work well.
    lothiandon1940 and blowby like this.
  15. blowby
    blowby
    from Nicasio Ca
    Is it hard yet?
    Budget36 and Johnny Gee like this.
  16. topher5150
    topher5150
    Not sure how I should answer that :D
  17. williebill
    williebill
    Nobody cares about your ****.
    Answer the question:D
    reagen, Budget36 and Johnny Gee like this.
  18. BJR
    BJR
    We use PC 7 at work for steering wheels. Works great, and forms better than JB. Not as runny.
  19. Budget36
    Budget36
    You owe me a sprite
    blowby and lothiandon1940 like this.
  20. error404
    error404
    from CA
    hm... yeah 24 hours nothing should still be tacky. Is this the regular old 2 part jbweld? I use that stuff all the time. I bet either you didn't get a close enough 50:50 mixture, or maybe was it extremely old? I've used stuff that is 5 years old or more (opened first 5 years ago) and it's been fine for me, but maybe it does have a shelf life.
    you could try putting a hot light up close to it, see if that helps it go?
  21. error404
    error404
    from CA
    interesting, that's my one complaint about JB, sometimes it's a bit too runny. I'd like to give PC 7 a go. You use the "original" flavor?
    BJR likes this.
  22. gimpyshotrods
    gimpyshotrods
    PC-7, PC-11, or Marine-Tex.
  23. Truck64
    Truck64
    from Ioway
    In the .mil we used a lot of different stuff, the sheet metal guys used to use a Hysol product on rotor blades that everybody universally just called "the pink ****", about the same color as Bazooka bubble gum. That was some stout stuff. I bet it would work great for steering wheels.
  24. indyjps
    indyjps
    Get a little heat into it, 120 or whatever you think car interiors in the summer get up to.
    See if it kicks off, decide if you have to s****e it out.
  25. gsjohnny
    gsjohnny
    i cut up a mopar intake to make a single plane intake for my buick 350. it's held together with jb weld. even at 10k rpm it did not break. btw neither did the engine. lol
  26. 2OLD2FAST
    2OLD2FAST
    from illinois
    AFA I know , most epoxy does NOT chemically bond to most plastics permanently .
  27. ronzmtrwrx
    ronzmtrwrx
    How does the PC 11 sand compared to the PC 7 ?
  28. gimpyshotrods
    gimpyshotrods
    It's a little harder, but manageable. I would not fill a dent with it, but it is fine for steering wheel cracks,
  29. ronzmtrwrx
    ronzmtrwrx
    Thanks. I’ll have to order some and try it on a pretty rough banjo wheel I have layin around.
