Technical Jeep gears in ford toploader.
Discussion in 'The Hokey Ass Message Board' started by matty_j24, Feb 11, 2015.
  1. matty_j24
    matty_j24
    Hey guys! I'm doing a jeep top shift conversion on my 3 speed top loader using the shifter from a t150 cj jeep and have discovered that the gear set is pitted and will need replacing. Being in New Zealand it makes it a bit more expensive so looking to save some $$ if I can. Now I know the shifter bolts on but does anyone know if the gear sets inside are the same? Looking on Allstate gears website they list a new cluster for a jeep t150 and the tooth count on gear set seems to line up and the picture looks the same. Has anyone done this before I go and take a punt on the jeep gear set?
    Thanks
    Matt
  2. matty_j24
    matty_j24
    Oh and it looks like they run the same small parts kit from my research on eBay etc. I.e loose rollers snap rings thrust washers etc.
  3. mrspeedyt
    mrspeedyt
    three ways to find out...
  4. matty_j24
    matty_j24
    Thanks for that but that's what I'm trying to avoid.
