jeep rods
Discussion in 'The Hokey Ass Message Board' started by thrasher, Feb 4, 2007.
  1. Cappa
    Cappa
    Whoa! Never said she was my girlfriend...just an ugly girl...Nope, I was solo for this flight. The jump itself was about 3-4 feet tall. But really steep. I just hit it fast and it would boost into the air. Second gear, low range, pinned. Oil pressure? I pretty much had the wind knocked out of me every time I did it so I wasn't paying attention. It was a fairly-tired Ram Jet 350 crate motor that had seen way worse. I was off the throttle in the air and for the landing anyway. It's hard on drivetrain if you are not.
  2. mustangsix
    mustangsix
    I would be happy to shorten your wait by taking the TR4 off your hands.....:)
  3. Codeman
    Codeman
    from SE Mo
    I am a subscriber to JP and I'd like to see it.
  4. Barrows
    Barrows
    from Union ME
    This tread is so much fun! You guy's are thinking outside of the box on this one. Cappa loved the mag!
  5. de-generator
    de-generator
    '47 wagon lowered with model A front sheet metal. It is sitting in the garage waiting for me to finish it.
  6. GlenC
    GlenC
    Thanks John. I did stick my nose under the back of the pickup bed and noriced a lot of heavy rust around the back of the frame. They used these pickups in the cane fields around here, so they were always in damp conditions. The ch***is rails appeared to be dead flat right trhough, and almost straight as well, bit like a T Ford ch***is on steroids, so making up a hotrod ch***is out of 4 x 2 or 6 x 2 box would probably be an option.
    Still thinking about this one.........
    Cheers, Glen.
  7. JSBriggs
    JSBriggs
    from Auburn, CA
    Glen,
    The difficulty with landrovers is because of their aluminum body, at first glance, they look better than they really are. Check the door frames and firewall (bulkhead) as well, as they are steel. The early series 1's had an 80" wheel base until mid '53 when then went to 86" and later to 88" on the short wheelbase trucks. I mention it because not all series 1 body panels bolt up like the 1958-2007 body panels do . Also check out the Series One Garage http://groups.msn.com/TheSeriesOneGarage/ Its an international MSN group with several guys from your neck of the woods and while they are more 'offroaders' than 'hotrodders' they can help point you in the right direction.
    BTW this is a Series II I'm working on, I may even have it going by next summer (but probably not) http://www.jalopyjournal.com/forum/showthread.php?t=172708
    -Jeff
