Jeep T5 trans in the torquetube
Discussion in 'The Hokey Ass Message Board' started by Stovebolt, Apr 8, 2008.
  1. Cabro32
    Cabro32
    from Pa
    Crazydaddyo what size of an order would you need to inspire you to make the Jeep T5 adapter?
  2. J Man
    J Man
    from Angola, IN
    Can you PM me info, I might take both of them. Thanks
  3. Crazydaddyo
    Crazydaddyo
    All of the V-8 units are sold. But you can use the Model A unit with the V-8 torque tube by using the model A ball flange and Clam shell.
    Doing a photo shoot for a Mag tech article this week end.
  4. Crazydaddyo
    Crazydaddyo
    Here are some pictures of the S-10 set up in a stock model A ch***is.
    mdimages likes this.
  5. Stovebolt
    Stovebolt
    Dan,
    I'm glad this thread popped back up again, as I've been meaning to ask you about an adapter plate and clutch setup to suit a GM gearbox to an original model A bellhousing, which I believe is what you run in your T.
    I hope I'm not out of line in asking you if you also have these available for purchase?
  6. 6inarow
    6inarow
    Is it the same adapter as in a 37-54 chevy torque tube?
  7. Stovebolt
    Stovebolt
    Tom
    If I am right, I believe you are asking if you can use his adapter to bolt a Chevy torque tube to a 4x4 gearbox ........ Then the answer is yes.
    You've just got overcome the differences b/w GM and Ford spline on the output shaft
  8. Crazydaddyo
    Crazydaddyo
    Here is and adapter that I just made for Stovebolt for a Chevy t-5 to AA bell housing. This fits the stock Model A flywheel housing:
  9. johnny bondo
    johnny bondo
    from illinois
    so how much more does this cost compared to just getting an open drive conversion for the rear?
  10. BCCHOPIT
    BCCHOPIT
    I am thinking about the same or cheeper because you don't need to have a custom drive shaft made.
    You can you the stock bones.
    If you go open you have to run a 3rd link to take the place of the T tube
  11. Flat Ernie
    Flat Ernie
    Tech Editor
    You likely will have to shorten the torque-tube and driveshaft...
    You choose this option, not for cost, but for keeping your torque-tube & rear suspension intact. There is almost no other reason. Open driveshaft is likely cheaper.
  12. cbillelder
    cbillelder
    Check out the article in the May, 2011 issue of Hot Rod Deluxe magazine on page 82. Steve Serr of the Miller Hi-Speed Head Co. makes all the parts to adapt a T-5 ****** to the Ford closed driveshaft axles. Their number is: 805-509-0893.
  13. white64
    white64
    from Maine
    Ok, I'm late to this dance.. but I just bought a model A coupe and want the look iof the old rear... want to go with a late flathead and 5 spd and discovered this link just today... (have had t5s in mustangs and put one in my avatar (at the time of that writing my avatar was a 38 Plymouth coupe (the one that bunred to the ground), with a flat 6 and a mustang t5 with an s10 tailshaft), loved it
    Went to Miller's site, nuthin there listing any of these parts.
    CDO:
    Typical questions you've likely answered a hundred times...
    What year chevy 4x4 T5?
    If you shorten the TT, do you need to relocate the radius rods or do you split the wishbones if needed (I've seen the pics where they are not split)
    Are the kits available?
  14. chrisntx
    chrisntx
    from Texas .
    I put a 84-87 F150 fully synchronized 3 speed with overdrive in my A, using an adapter for the torque tube, very similar to the first picture in this thread.
    Its a great transmission.
  15. Mart
    Mart
    Can only answer the one part, if you shorten the torque tube, you should retain the radius rods and shorten them to suit, still attached to the torque tube. You cannot use a torque tube and split radius rods on the same axle.
    Mart.
  16. general gow
    general gow
    MODERATOR
    did you make an adapter? or is it a commercially available part?
  17. white64
    white64
    from Maine
    makes sense that you can't split the rods! just wondering since no one mention them...
  18. Crazydaddyo
    Crazydaddyo
    The trans comes from mid to late 80's Chevy S-10 or GMC S-15 trucks.
    They are the only years that the T-5 came in the 4x4 trucks.
    The Wishbones have to be shortened.
    Kits are available from Steve Serr. at Phone: (805) 647-2766
    Fax: (805) 647-7578.
    Thanks.
  19. V4F
    V4F
    from middle ca.
    i have a good 6v fuel pump if one of you needs it ................ steve
  20. Crazydaddyo
    Crazydaddyo
    I'm getting ready to make another run of S-10 4x4 adapters.
    Anyone interested?
  21. millersgarage
    millersgarage
  22. fryguy
    fryguy
    Just came across this thread an I am interested in this setup. I want to put a t-5 trans behind my flathead in my '37 and keep the enclosed driveline. I am interested in purchasing an adapter
  23. All this talk of shortening radius rods..... it's not necessary. I shortened my 47 tt and driveshaft by 18". I just cut the mounting bracket off the tt and welded it on in the new position. Much easier than ****ging around shortening the rods.
  24. hammeredt
    hammeredt
    Yes sir. I need one.
  25. Mart
    Mart
    You're right, of course, but the later rears do have the shortest radius rods already, you may not be able to do this on an earlier rear.
    Mart.
  26. 47chevycoupe
    47chevycoupe
    from Finland
  27. brokenspoke
    brokenspoke
    I'm almost finished with my conversion.....I have shortened the model a driveshaft with a coupler at the rear...I'm using a Halibrand 101 quickchange.....The coupler is cross drilled for a pin.....my lower shaft of the quick change isn't drilled....does the coupler need to me pined ? or any suggestions on drilling the lower shaft???? I might add that the quick change is already built....
  28. Crazydaddyo
    Crazydaddyo
    I pinned my quick change. I don't remember it being that difficult
    If I remember correctly, I did it in the car.
    I think it needs to be pinned so that the shaft is fixed.
  29. brokenspoke
    brokenspoke
    How did you drill the shaft? My concern is getting it aligned correctly so the pin will fit....is there any kind of alignment jig to guide the drill?
  30. sanfordsotherson
    sanfordsotherson
    from So. Cal.
    "I'm getting ready to make another run of S-10 4x4 adapters. Anyone interested?"
    Yep. What will the adapter kits run $$$?
