Jeep T5 trans in the torquetube
Discussion in 'The Hokey Ass Message Board' started by Stovebolt, Apr 8, 2008.
  1. Crazydaddyo
    Crazydaddyo
    Hey guys,
    I talked to the patern maker today and he told me that I should have castings in the next week or so. I don't know how many, but 5-10 would be a good sample size to make sure the patern was good.
    Dan
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    Dan - I ***ume these are for S10, not Jeep, and Model-A TT, not V8??
  3. This thread is so cool, too bad I started my open conversion just before I saw this!@^&*#%^#!
  4. Crazydaddyo
    Crazydaddyo
    Yes the first one will be for the S-10 trans. It will work with both the A and V-8 torque tube. The only differance will be the mounting holes for the ball cup mount for the T/T.
    I've contacted another pattern maker about the Jeep adapter and I will probably have him start a pattern for it soon.
    Dan
  5. sko_ford
    sko_ford
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    Dan,
    Outstanding. Will your one casting do both A and V8, or will it be machined to order?
    Great to see this coming along!!:D
    Motmo likes this.
  7. X38
    X38
    Great thread and it provides a solution for me. Just have to get to that project!
  8. I SMELL SMOKE
    I SMELL SMOKE
    when will they go on sale and how much $ will yhey cost?do you got a waiting list?
  9. Crazydaddyo
    Crazydaddyo
    Ernie,
    The S-10 casting is the same for A and V-8 but the mounting holes for the ball cup are different. There will be two A versions (Early and Late) and a V-8. I will probably carry inventory of all versions so that I can ship them when they are ordered.
  10. Crazydaddyo
    Crazydaddyo
    I'll pm you with the details.
  11. brokenspoke
    brokenspoke
    I have one question Crazydaddyo?? I see in your post the s10 trans has a transmission mount...Is this necessary??? I'm wondering since the bell housing is supported is it ok the just let bell housing carry the weight of the transmission...simular to try 5 chevys.Thanks
  12. Crazydaddyo
    Crazydaddyo
    In the ones that I have done, I have used the trans mount. My reasoning was that in a torque tube driveline, the torque tube is the rear suspention. Like the swing arm on a motorcycle it controls the movment and the tourque of the driveline. Using the rear trans mount transfers this torque to the frame.
    From what I know of the tri 5 Chevy driveline, it is an open drive shaft and they use parralell leaf springs to control the rear end.
    Early Ford rear ends use a transverse spring and that spring can not control the torque of the driveline when you remove the torque tube. That is why when converting it to open drive there has to be some sort of torque arm attached to the center section of the rear end and the frame to keep the rear end from twisting on the axels.
  13. Claych
    Claych
    from Ca.
    CDO,
    on the 5'th gear issue, the Mustang GT had 3 ratios in progressive years,
    83 1/2 (84?) -.725, 84, -.625 , 85 UP -.675.
    Do you know if the O/D ge****t will work on the Jeep/ S-10 mainshaft/cluster?
    I do know the T/5 max torque capacity is nothing to write home about,
    (265 ft /lbs until 89 , then 300 in 93)
    THX for any input
  14. Flat Ernie
    Flat Ernie
    Tech Editor
    Not sure if NWC & WC 5th gears will interchange - don't have a pair to check. However, you can't just put a .62 into the Jeep and expect to get .62 - it has to do with the first gear ratio times the OD...I do know putting the Astrovan 5th into the 3.76 ge****t results in a pretty good OD (.68 IIRC)
    Do not be misled by max torque capacities - these are 100K mile ratings. Biggest weak point is the case - if it were cast iron, there'd be less issue with the gears trying to climb each other. Gross rule of thumb - higher gears (lower numerically) = higher torque rating. That's one of the reasons the 2.95 aftermarket ge****t for the Mustangs is rated higher than the factory 3.35...in addition to some improved metallurgy.
  15. brokenspoke
    brokenspoke
    I'm using the TT not converting to open drive...
  16. Crazydaddyo
    Crazydaddyo
    You missed the point. If you remove the rear trans mount you transfer that torque to the rear engine mounts and that may put excessive force on the trans and bellhousing. The Tri 5 set up isn't subject to that stress because the torque is controled by the rear springs.
    In my opinion you need the rear trans mount.
  17. Snarl
    Snarl
    Gears are not the same between the WC and NWC...
  18. Crazydaddyo
    Crazydaddyo
    I do not know if the Mustang gear set will interchange with the Jeep gears. The swap I did was to put the 1st-4th gear sets out of a Chevy S-10 2wd trans into the case of the Jeep. I did find that I had to use the 5th gear set from the Jeep because the spline on the Jeep output shaft (which is retained in this hybrid) Is different then the Chevy and the gear tooth pitch and angle are different also. That forced me to use the Jeep 5th gear on both the output shaft and the counter shaft leaving an overdrive ratio or .86.
  19. Flat Ernie
    Flat Ernie
    Tech Editor
    You probabaly don't have .86 because you're using the 3.76 1st ge****t from the S10, right? 5th will be some other combination, actually - probably better if I had to guess. Here's a post I did when figureing out the OD ratio if I used the Astro ge****t - of course, I haven't checked the splines, so it's probably the same as yours...have to use the Jeep, but that helps me...
    http://www.jalopyjournal.com/forum/showthread.php?t=254912
    With Astrovan input and cluster + Jeep 5th, I end up with .69 OD ratio...
  20. brokenspoke
    brokenspoke
    I understand now..thanks
  21. Flat Ernie
    Flat Ernie
    Tech Editor
    I think in an open drive conversion, you'd be fine without the rear mount, but as Dan mentions, in a torque-tube arrangement, you probably need it.
  22. farna
    farna
    That adapter will work with the last of the Rambler Torque tubes too. It doesn't use a cup, but uses a square flange with a rubber bushing. So a 1/8" thick steel plate would have to be made to adapt the Rambler torque tube to the adapter, but that would be easy. I'm talking about 63-66 big Ramblers (Cl***ic, Amb***ador, Marlin, Rebel). I just don't know about the length of the T-5 vs. the Rambler T-96 (for sixes) or T-86/89 (for the 232 six and 287 V-8/327 V-8). The V-8 shaft in the tube is a two piece unit that's tubular in the front and can be shortened pretty easy, the six shaft is like an axle shaft and would have to be resplined. Well, it could be cut and a sleeve made for it and welded on both ends -- I've seen Jag IRS axles done that way. Of course shortening the tube is easy.
  23. sidevalveguru
    sidevalveguru
    hi Crazydaddyo, would you volunteer what you did for the universal splines?
    Many thanks!
    SvG
  24. Crazydaddyo
    Crazydaddyo
    I made the yokes.
  25. sidevalveguru
    sidevalveguru
    My apologies, i somehow entered this thread in the middle. If you are offering this for sale, I'M Interested!! I also spe******e in this sort of thing, but i want to both save my time, + reward a fellow '*******izer' (used with the greatest affection; it's a skill that relatively few devolop these daze!!)
    As always, there are a few 'flies in the ointment': i have a Ford Motorsports 'WC-Z', new. I need the shortest possible version. (~34" firewall to axle c/l)
    Can U e-Mail me directly?
  26. sidevalveguru
    sidevalveguru
    It might serve you well to @ least look @ these.
    They are the progenitors of a whole "boat-load" of sprint-car & midget style torque tube QC rear-end setups!
  27. Sorry if i have missed something , but is there an advantage to this, over an open drive conversion?
  28. Wildfire
    Wildfire
    Yes, the big one is you don't have to completely redesign the rear suspension - ladder bars, 4-bars, truck arms, coil-overs, etc. It also looks more "vintage".
  29. sko_ford
    sko_ford
    it keep the structural integrity of the banjo design intact with out have inf to add a torqure arm. and it looks killer / all early dirveline looking
  30. So, would i be right in thinking that open drive works well with parallel leaves but not transverse leaves or am i missing something
