Hot Rods Jerry 's 32 5 Window Project
Discussion in 'The Hokey Ass Message Board' started by HomemadeHardtop57, Sep 7, 2016.
  1. HomemadeHardtop57
    HomemadeHardtop57
  2. HomemadeHardtop57
    HomemadeHardtop57
    ls1yj, loudbang and Stogy like this.
  3. HomemadeHardtop57
    HomemadeHardtop57
    New bottom and lower skin on door. Gaps getting dialed in
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
  4. 383deuce
    383deuce
    Jerry, This is looking very bad ***......kadoos to you and Andy for all the skills...Keep on doing what your doing....
  5. HomemadeHardtop57
    HomemadeHardtop57
  6. HomemadeHardtop57
    HomemadeHardtop57
  7. loudbang
    Beginning to look like it came from the factory chopped :)
    kidcampbell71, Runnin shine and Stogy like this.
  8. AULIZ
    AULIZ
    Rock !
    A
  9. 383deuce
    383deuce
    Looking great and moving right along my friend.....Keep it going.
  10. HomemadeHardtop57
    HomemadeHardtop57
    New Drip rails on and pinholes on top of cowl under windshield welded up
    [​IMG][​IMG][​IMG]
  11. Pete
    Pete
    Looking nice fellas.
  12. HomemadeHardtop57
    HomemadeHardtop57
    ls1yj, Splitbudaba, Rich B. and 3 others like this.
  13. HomemadeHardtop57
    HomemadeHardtop57
    ls1yj, Stogy and loudbang like this.
  14. PAracer
    PAracer
    Nice work Jerry. How many dropped axles have you painted on that floor? [emoji41]
    Stogy, loudbang and '52 F-3 like this.
  15. GaryN
    GaryN
    Nice work. Wondering how you attached the new drip rails? Spot weld from inside of the roof?
  16. Just checking in and it looks amazing. I think you should do a separate thead on the louvers. How to make the tool and then use the tool for stamping.
  17. HomemadeHardtop57
    HomemadeHardtop57
    That's Andy Kohler's floor. The garnish moldings are going to be chrome plated so He's tigging them up for me. After, I'll sand and prepolish...getting a bit fancy pantsy on this one. I believe his floor has seen quite a few dropped axles
  18. HomemadeHardtop57
    HomemadeHardtop57
    I just might
  19. HomemadeHardtop57
    HomemadeHardtop57
    Holes were drilled in drip rail channel, weld through primer was applied, and drip rail was clamped on and plug welded from the inside.
    ls1yj, -Brent-, 343w and 4 others like this.
  20. Hendee
    Hendee
    I'll second that request.
  21. HomemadeHardtop57
    HomemadeHardtop57
    Experimenting with an idea this morning for my headlights..we'll see if it works out.
    Stogy likes this.
  22. HomemadeHardtop57
    HomemadeHardtop57
    Lots of sanding and polishing to go but came out pretty neat. I acid etched an art deco pattern into a pair of br*** headlight buckets for the new car I'm putting together. I'm going to polish the raised beams ..then tape them off and blast the whole bucket. After the tape is pulled I'll have an even matte finish on the buckets and a polished raised design. They did this on saxophones in the 1920's and 1930's
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    ls1yj, oliver westlund, Stogy and 4 others like this.
  23. HomemadeHardtop57
    HomemadeHardtop57
    Little hand polish ..you can really see how deeply the pattern is etched into the br*** buckets
    ls1yj, Stogy, Tim_with_a_T and 3 others like this.
  24. '52 F-3
    '52 F-3
    from Central PA
    very cool, I like a lot.......
  25. HomemadeHardtop57
    HomemadeHardtop57
    Also cleaned up the gl*** markers with some 3000 grit
  26. frdsuperduty
    frdsuperduty
    from Lewes De
    I'm all for different,but this one gives me pause.Maybe Too much going on???
  27. HomemadeHardtop57
    HomemadeHardtop57
  28. DDDenny
    Not that Jerry needs anyones approval, especially mine, but I like everything I've seen.
    I opened my mouth before I fully knew Jerrys' skilset and I'm looking forward to how the front sheetmetal turns out.
  29. HomemadeHardtop57
    HomemadeHardtop57
    No sweat Denny ...ive got a few hood ideas
  30. HomemadeHardtop57
    HomemadeHardtop57
    While I'm getting the headlights squared away, Andy tig'd the garnish moldings up. I'm going to send these out for chrome and a tig seam is so much easier to blend. He did a great job. Im going to pre polish them then send them out for a shiny dip.
    ls1yj and Stogy like this.
