Hot Rods Jet Fighter Canopy (Not Off Topic)
Discussion in 'The Hokey Ass Message Board' started by Candy-Man, Jun 26, 2010.
  1. oldfart36
    oldfart36
    I recieved your Pm and will answer once I've checked. In the past guys used all kinds of combos, including tailgunner ops. The problems with military windscreens and canopies is most are to heavy and to big. The last person I ended up helping with this problem that was on a budget used left and right sections of the windscreen off an A-10 Thunderbolt, only problem with using windscreen sections is you end up with a seam down the center. I have A-10 forward sections at present along with other combos, but my fighter combos are just to big. The best thing for you to do if your buget can swing it is to contact PITT Aircraft and or they're suppliers, some of the small one piece canopies are a perfect size.
    Hope this helps, will check further for you.
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    I'll second checking out the homebuilt airplane suppliers like Aircraft Spruce and Wick's. You may end up going to kit suppliers directly...
  3. Candy-Man
    Candy-Man
    Excellent, I have looked at Aircraft Spruce Canada web site. They have numerous canopies listed for glidders. I'll be contacting them Monday.....
    Thanks Again...
  4. Candy-Man
    Candy-Man
    I'll let you know if I strick out up here first.... Thanks for the offer....
  5. Jeff Norwell
    Jeff Norwell
    MODERATOR
    This is what makes this place so great.... folks offering there solid ideas and info....
    thanks again fellas!
  6. So, where is the artists concept of the thing? I think one of you can draw a littl? ;)
  7. Candy-Man
    Candy-Man
    Norwell has his elves working on it as we speak..... They just finished breakfast...
  8. ooops
  9. Moose223
    Moose223
    You might try Hannigan M/C Fairing windsheilds for the early frame mounted BMW and others, I bought one years ago and the measurements are close and just might be the ticket. They might still be around.
    Moose:rolleyes:
  10. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Oh there is some quickie sketches floating around....:) nothing special or concrete....
    The wing may have to go..... cause it may be cl***ified as a Liner...and Candy man wants in the GL/XO cl***.....
    But I thought a small dorsal fin would be neat.
    Any how.. that Spruce place is 20 minutes down the road... going there this week....And we just found out that any old vintage glider canopys are usually brittle and junk.....new is the way to go...
  11. mike1951
    mike1951
    from Colorado
    What about a Pitts Special?? They did have that show on "car czar" where they rebuilt the dream truck...you know the 54 olds converted into a truck...did you see that one? The windshield cracked and they formed another one out of plastic/ like lexan...they heated it up in a furnace over a mold and it formed to fit the old windshield.... Why not build a mold of what you want and form it to fit?
  12. Cool! thanks for the sketch Jeff!
  13. Chaz
    Chaz
    I dont have my rulebook in front of me , but if you're planning on running that thing I'm pretty sure the bubble has to be Lexan, not plexiglas. The Lexan is a ****** to form...
    If that little fin puts you into the liner cl*** we are in a heap of trouble.
    It shouldn't be cl***ified as a liner unless you cover the wheels. Open wheeled with shaped bodies are lakesters.
  14. mike1951
    mike1951
    from Colorado
    you are probably right.
  15. FRITZ
    FRITZ
    I got what you need!
    I have 2 in stock 28W by 46L and about 13 or 14 inches deep
    I can get you a smaller size of about 22w X 28L by about 11 deep
    Jeff has my number
    FRITZ
  16. Chaz
    Chaz
  17. crash11049
    crash11049
    From 1960 article in Best hot rods by Ed Roth sorry photos not scaned
  18. Daddyfink
    Daddyfink
  19. Candy-Man
    Candy-Man
    I'll need some special tires for ice, do you have any ? Ha Ha Ha
    I'm just a litte east of the Qunite area.....
  20. Candy-Man
    Candy-Man
    Are you running front runners all around your tank? If so, how tall is your rear tire?
    Thanks......
  21. great post with lots of info. keep it going
  22. Chaz
    Chaz
    Yep, frontrunners all around . The fronts are 28 inchers, the rears are 26 inch. The car is front wheel drive however, so the larger tires are the driven ones. The manufacturers do not recommend using their 30 inch tire for landspeed racing.
  23. dana barlow
    dana barlow
    from Miami Fla.
  24. scottybaccus
    scottybaccus
  25. Kan Kustom
    Kan Kustom
    This is a great thread! Bump !
  26. mike1951
    mike1951
    from Colorado
    I go back to Chaz....check the rule book and make sure that what you are droppin cash on will be correct for your cl***...
  27. Candy-Man
    Candy-Man
    Dave is that the building on the west side of the 400 south of 7, with the bubble windows on the side of the building?
  28. Candy-Man
    Candy-Man
    Excellent that is the place, however; I called them after your posting and they will not venture away from the usual sky lkights, etc. as it takes away from their production... And refuses to touch Lexan molding....
    Thanks for positing their web site....
