History Jim Hall's Chaparrals-American Innovation
Discussion in 'The Hokey Ass Message Board' started by miller91, May 19, 2009.
  1. hasty
    hasty
    What does the air scoop on the hood of No. 66 do?
  2. miller91
    miller91
    66 was used on many of these cars, which are you referring to?
  3. rocketbob
    rocketbob
    from West Texas
    <TABLE cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD vAlign=top>The Chaparral 2J was driven Friday, July 17<SUP>th</SUP> around 5:30 p.m. at The Petroleum Museum. The 2J ran for approximately 10-20 minutes in the front circle. The running of the Chaparrals is part of the routine maintenance to keep the cars in running condition. It's really cool that they are being keep in running condition and not just as museum pieces
    </TD></TR></TBODY></TABLE>​
    The garage area was open for viewing before the car ran, but we got there too late.
  4. hasty
    hasty
    Sorry, very unclear question. I was wondering about the air scoop that leads to the driver on the hood of the open top car above.
  5. miller91
    miller91
    You almost guessed it, it's to cool the driver. These cars were built and tested in Midland Texas after all!
  6. I believe this would have been from the 2E. Possibly when the wing failed at Bridgehampton? The 2G version was converted to the 2F endurance car's upright Watts linkage to stabilize the wing. 2G had MUCH wider rear tires as well.
    What an awesome look at the geometry that Hall tried so hard to keep "top secret"... Where the hell did you ever find that?
    BTW I was also at Laguna in 05 to see that display. AWESOME. Seeing the Toyota Group 7 car was the thrill of a lifetime as well.
    The weekend wasn't all happiness. I was crew chief for Brian Blain on the Lola T163. We had valvetrain problems in the 509, and worked half the week after the Pre-Historics getting it fixed. In the Can-Am feature Brian was running second right on John Morton in the Mc Leagle. They were leaving the field at 2 sec per lap and Brian was just biding his time. The shift linkage broke coming onto the frontstretch. That was bad enough...but on the NEXT LAP, Morton sheared the input shaft off the Hewland in exactly the same place! Nobody else was even close...
  7. Ivory Hunter
    Ivory Hunter
    from Texas
    Was at the long beach california swap meet a couple years back and a guy was selling a pair of chaparral big block chevy valve covers. he wanted $700 for them, i looked at them, and only one had the chaparral script, the other had all the holes for the dry sump, would have bought them if both had the chaparral script. i thought about it and walked back a couple times and offered $500, said no he was selling for a friend . I was building a blown motor at the time and couldent justify it. Wish i would have bought them.
  8. 2Hep
    2Hep
    Note background right of Ed Welburn's desk in his office at GM Design. Could at least one of those be an upcoming Chaparral that GM has in the Skunk Works?
  9. 2Hep
    2Hep
    Not Right but Left of the picture cropped out
  10. 2Hep
    2Hep
    That was out of MotorTrend's Interview with Ed Welburn
  11. hasty
    hasty
    Thank you. Presumably there was quite a lot of buffeting for the driver, otherwise they would have just taken out the screen? The addition of the duct must add weight (quite high up) and drag.
  12. miller91
    miller91
    You bring up good points, Hall was a clever guy, especially with aerodynamics. The duct bleeds higher pressure air off of the nose with minimal drag, and the fibregl*** and lexan duct is pretty thin and light, so weight penalty is small. His Chaparrals are FULL of tricks, and are quite amazing machines ahead of their time.
  13. hasty
    hasty
    Thank you Miller 91, and thank you very much for posting all the pictures. I am familiar with the fan car but not so much with the other cars. The wing mounted on the hub in the drawing you posted is very similar to the idea in the much later Lotus 88, one of Colin Chapman's last innovations. If you have any more material, I for one will be a grateful reader.
  14. ct1932ford
    ct1932ford
    I remember standing on the track early foggy morning in the 60's and seeing the two Chaparrals on open trailers coning across the track into pit area. There first appearance with wings. IMG_9427.jpeg IMG_9428.jpeg
